Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
The printer prints but no ink is on the paper
I just recently started having a problem with my printer not printing any ink on the paper but it does everything else like it is printing
  • 2 more comments
  • kevinkwsa Oct 05, 2008
    i got a replacement printer as i had not had the other one long when i pit in ink it will not print a configaration page
  • puremoat Oct 06, 2008
    just put a new black ink in and it does not show up. The color does but not the black
  • firewoman1ce Oct 07, 2008
    it will not print black and it prints the colors faded I've replaced both cartridges and still nothing
  • Anonymous Mar 12, 2014
    THE PRINTER IS ADVANCING PAPER, BUT NO INK ON PAPER
    Problem Solver:
  • 12 Answers
Try first to upgrade the firmware of your printer, then turn off your printer, unplug the power cable at the back of your printer and then replug it back again after 20 sec then turn on.
try to clean the printhead,deep clean, then calibrate the printer.
if it still printing blank page, try to remove and then reseat the printhead and the ink cartridges.
or go to the kodak website for troubleshootin www.kodak.com/go/itg
hope this will help you
Posted on Oct 03, 2008
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
Samsung CLP 510 - won't print on photo paper.
Have you changeed the PAPER type to (specialty or card stock) this always work for me. Your printer will have these setting
Aug 31, 2008 | Samsung Office Equipment & Supplies
Printing misaligned color blotches, little squares off to the
Are you using genuine inks or compatibles/refills? Have you cleaned / aligned the print heads recently? Does it only happen on the second print? Could be a case of excess ink getting onto the rollers which then get hot and deposit the ink on the next paper coming through.
Also make sure you've selected the correct paper type before printing.
Oct 29, 2009 | Epson Stylus Photo 1280 InkJet Printer
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
No ink coming out on my Canon S900
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jun 29, 2009 | Canon S900 InkJet Printer
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Brother DCP-120C Printer - Does not print black, Black and magenta cartridges renewed with new Brother cartridges. Black ink level reset OK but not magenta. Have tried automatic head cleaning but still no...
have you recently had a paper jam. somtimes pieces of paper can become trapped under the print head which restricts the printing. if there is and its been there for a while the print head may need to be wiped/cleaned( a bit tricky) then a couple more print head cleans.
Nov 04, 2008 | Office Equipment & Supplies
Can print A4 but not photo paper
It looks like you have a problem with the pick up roller....try removing the roller and washing it with water dry properly and insert it back to place ..this is temporary fix.....and mite not work 2..u need to replace this roller....if it continues to trouble you
Oct 31, 2008 | HP PSC 1410 All-In-One InkJet Printer
Pulls paper through, but doesn't actually print anything on the paper
check to see if the cartridges are in all of the way. because it may not have punctured the ink seal...
Jul 10, 2008 | HP Deskjet D4160 InkJet Photo Printer
Printing is very green
I would suggest that you clean the carriage assembly with a q-tip and at least 90% solution of isopropyl alcohol. Then I would check the carriage rest area, using a clean paper towel carefully soak up any excess ink there. Then check the paper path from start to end and make sure that there is no paper pieces.
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
80 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
