Question about GE Profile JVB67HWW 36" Telescopic Downdraft Ventilation System: White on White Kitchen Hood
Wouldn't raise model # jub66w1ww
  • 1 more comment
  • Anonymous Jan 26, 2009
    HELP!
    GE Profile JVB67HWW 36" Telescopic Downdraft Ventilation System: White on White Kitchen Hood will not raise itself.
    please help
    my downdraft won't raise
    thanks
    peter
  • enchen Feb 16, 2009
    We have a GE JVB37 Downdraft Vent, 30". One day I pushed the raised/lower switch. It raised about halfway and then started making loud bumping noises. I pushed the raised/lower switch again and it lowered all the way down but the motor would not shut off so I unplugged it. If I plug it back in, the motor hums all the time, and the vent will not raise out of the counter when pressing the switch.
    It looks like we're covered under a service warranty (3 weeks short of expiry). GE is coming to take a look this week so we should have an answer soon...
  • 4 Answers
The GE repair guy came and fixed our vent! He opened up the cover and found that the pivot arm was above where it was supposed to be. It had gotten dislodged or something. He replaced the pivot arm with a new one, Part #WB02X10303, which is supposed to be a new design that won't get off track so easily. Works great now.
Posted on Feb 27, 2009
Cummins 5.9 ISB low power?? What could the problem be?? What is the max Turbo boost?? Can boost be raised??
If you have low power it's very possible that the turbo is gone, I would check that and wouldn't mess with the boost as that can cause way more problems than what it's worth.
Oct 22, 2012 | Cars & Trucks
Hi I have a very dependable tuck..a 96 toyota t100 2wd with the v6 engine.. however I'm very worried when I see my oil pressure gauge drop very low at idle. But it raises to about halfway reading whith...
You might have. But it could be the sending unit, or the guage. You could take it somewhere and get a guage hooked directly to it if it's a real concern. On the other hand, it could be just fine. And if it's not knocking or burning oil, I wouldn't worry about it.
Nov 15, 2011 | 1996 Toyota T100
Removed part of te starter but can't get the rest out. how do i get it all out
Wouldn't be the first car you have to half raise the motor or whatever you can to achieve the goal.
Aug 11, 2011 | 2003 Oldsmobile Alero
136) it will start but quits right after .I had it servicedand the carb.was checked and parts were installed.Its still the same"""it still won't run""
I don't know who serviced it, but if you just had the work done, and it's still not right, you should take it back and tell them to fix it properly. You should owe nothing also, if you already paid them for the work.
I am sending you one of my Tips that will fix the problem:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
But I wouldn't do it until you raise cane with the service person and either get them to fix it, or give you your money back.
Good Luck,
Jim
Aug 03, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
My 2003 GMC Yukon rear hatch hydraulics is broken. To load into the back of the Yukon, I have to raise the rear hatch and then hold it up while I put things in the back. What's a good estimate of...
You just go to an auto parts store or dealer & buy the struts
You don't pay a repair shop to put them on
You wouldn't have someone replace your wiper blades
Same thing,simple.
Jul 17, 2011 | 2003 GMC Yukon XL
2002 gmc extended cab sonoma fuel pump replacement
Drop fuel tank, use brass drift and rubber hammer to unscrew retainer ring on top of tank. (Don't use anything that can cause a spark) Very carefully pull fuel pump and fuel level sensor out of tank.
Separate pump from unit and replace with the new pump. Wouldn't hurt to replace filter sock or filter if this model has one.
Carefully slip unit back into tank, replace seal and locking ring, ensuring it is tight.
If hoses and wires are long enough I check for proper operation before raising the tank all the way in place.
Once satisfied pump and fuel gage is working, replace tank in frame.
Apr 09, 2011 | 2002 GMC Sonoma Extended Cab
Kitchen Ranges Logo
1,348 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
