Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
HT 1000 Set Scan mode
I have a HT 1000 with no info on use. Need to set scan mode.
  • 3 more comments
  • wefolks Oct 03, 2008
    I have 16 ch to use if i want. I only want to scan 4 or 5. I do not know how to set that up.
    how do I do scan on/off
    Great it works!
  • Anonymous Dec 05, 2008
    i have a 2 channel motorola ht1000 how do i scan.
  • eradiostore
    eradiostore May 11, 2010
    You might also find of interest a video about an HT1000 posted at http://www.youtube.com/watch?v=eUDvKMyvh...
  • eradiostore
    Could you clarify what you mean by "set scan mode"?
    Are you wanting to know how to turn scan on/off?
    Or are you inquiring about installing the scan feature, and/or selecting your scan channel list?
  • Motorola Master
  • 1,654 Answers
First, your radio must have one of the side buttons programmed to be scan on/off. You will need to experiment while one or more of the channels is active and press the side button to see if it puts you in scan mode.
If it is, most likely a short press turns on scan, and a long press would be nuisance channel delete. This feature will temporarily eliminate a channel out of your scan list for the time your have your radio turned on. Once you shut the unit off and turn it back on, it would return to the original setting.
The only way to have a button programmed for scan/nuisance channel delete, is to us Motorola propritary software available to dealers and certain businesses and governement agencies. If you are needing to turn on scan or change a scan list, you would need to have the radio reprogrammed. This typically will cost between $25 and $40 at more dealerships.
Posted on Oct 03, 2008
Tip
How to exit from SAFE mode on Audi Concert radio
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer! For Audi Concert the sequence of programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
on Mar 19, 2010 | Audi A4 Cars & Trucks
I need directions to remove radio from safe mode.
IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for 2004 Audi A4 radio is:
Please do rate my response. Thanks!
Jan 27, 2011 | 2004 Audi A4
I need a code for my audi a4 its in a SAFE mode
The sequence of programming for 2001 Audi A6 radio is:
Jan 05, 2011 | 1999 Audi A4
Cant get radio out of safe mode
How to get 2006 Audi S4 radio out of safe mode: IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for Audi radio is:
Nov 27, 2010 | 2006 Audi S4
I have an audi A4 Quatro avant 1998, the radio is locked SAFE mode, I have the code but I do not know what to do.
How to exit the 1998 Audi A4 radio out of SAFE mode: IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
Nov 27, 2010 | 1998 Audi A4
My car radio is in safe mode and i need to take it out
Aug 26, 2010 | 1998 Audi A4
Je possède une jetta 1997. j'ai un problème avec le code de la radio. Je fais "Mode Scan" et par la suite le chiffre 1000 apparait. Mais je ne suis pas capable de changer les chiffres pour entrer...
Aug 15, 2010 | 1997 Volkswagen Jetta
How to set channels to scan on motorola ht 1000
On the HT1000, there is an A, B, C toggle switch just under the On/OFF/Volume control knob.
When set to A, the radio is IN the scan mode.
When set to B it is NOT in the scan mode.
When switched to C, it is in the scan program mode. There is a green button on the left side above the PTT switch. When you set it to C, you switch the CHANNEL SELECT knob to the desired freq you want to add to the scan list. When there, you push the green button. ONE push gives you a red indicator light on the top of the radio. A 2nd push gives you a GREEN light displayed. A 3rd push gives you NOTHING lit up.
The 1st push (RED light) means you have selected THIS freq as your PRIORITY channel of your scan list when scanning.
The 2nd push (GREEN light) means it is just IN the list, not as a priority channel.
NO light means it is NOT entered into the scan list.
Once you have your list set up, simply flip the A,B,C switch back up to A and you're scanning what you selected.
HOWEVER All of the above is dependent on whether or not the ORIGINAL setup programming from the factory set the radio up for these features to work. If it WASN'T set up that way, you'll have to have it reprogrammed to activate the buttons and the toggle switch for those features to work.
Jan 27, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
My sanyo dwm-3900 is on progressive scan mode how do i fix this
If your DVD players is set to Progressive Scan Mode, tehn ther would be a light indicating it is so. The light is labeled P?scan on the bottom right side of your display window.
You can disable/turn OFF the P/Scan mode in the "Setup menu".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
463 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
