Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub zero 650-display
The display is flashing "service" and 05 as freezer temp and EC as fridge temp. Can it be reset? Or does it really need a service call?- I have a 650 S and it is flashing "service" and the fridge temp is about 6 degrees higher than it should be. I've taken out off the top cover and cleaned dust out of the system but, other than that, not sure what to do.....reset or does it need a service call?
  • kccboy2004 Oct 21, 2008
    i have the same problem
  • jmwillisvill Nov 18, 2008
    help!!!!!
If you cleaned out the condensor unit, your problem is probably a bad evaporator. Schedule a service call. If the condensor was really dirty then you may have just compacted the dust into the condensor in which case a shot of CO2 would be a good idea.
Posted on Oct 07, 2008
My sub zero service light and EC 24 are flashing, fridge is getting warmer...suggestions?
The ec 24 alarm is from a sensor that is located behind the freezer wall and connects to the control board in the ref. When the temp gets to a certain point the sensor will trip giving the alarm. If the temperature in the freezer is gone up but is around the 20 -30 degree F range, I would remove the grate that covers the compressor and check to see if the fan is running and if the coils are dirty. Either one of those can cause temps to go up. If the fan is running and the coils are clean, Call a service company because you possibly have a sealed system issue
May 06, 2012 | Sub-Zero 632 / S
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Frost accumulating on back of fridge - service light blinking
YOUR EVAPORATOR IN THE FRESH FOOD SECTION IS LEAKING FREON. THIS IS COMMON WITH EVAPORATORS IN THIS AREA. 12 PART WARRANY OR 6 YEAR FULL ON THIS. SUB ZERO HAS SUPERIOR CUSTOMEER SERVICE AND MAY COVER FULLY IF OUT OF THE 6TH YEAR. 1-800-222-7820 CALL THEM AND ASK.
Apr 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
The control panel flashes "EC" where the fridge temp is displayed. The word "service" is also flashing.
"EC 50" means excessive refrigerator compressor run time. What is the serial number? Is the condenser fan running? Can you feel airflow from the left side up top? Is the strip between the fridge and freezer hot to the touch?
Mar 10, 2010 | Sub-Zero 680 / F
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
I have a ten year old Sub-Zero 650. The "vacuum condenser" has been displayed for over a year even though the coils have been vacuumed and are kept clean. The fridge has been working fine despite the...
Look on your sub zero for more model numbers. I have found some information indicating that the refrigerator thermostat may be the problem but need those numbers to confirm. Thanks, Sea Breeze
You can also find a user manual at this link
http://safemanuals.com/zearchres_663.php
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
496 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
