Question about Electronics - Others
Verbatim Store 'N Go 1GB USB drive no longer lights up
This unit no longer lights up, nor is recognised by my or other PC's. Although the msg "New Hardware Recognised" appears, I get "Please insert a disc into drive F (G whatever)" and can't read/write to it.
I have tried cahnging the disc anmes G, H etec, to no avail.
I read somewhere that this unit may have shorted out, so that might mean that it's a total loss. Is there any (verbatim) means of getting the data back?
Thanls
  • Anonymous Nov 24, 2008
    I insert it into my laptop, but it light up as it normally should do, I even tried it on other computers but it still doesn't work, it think because I lost the cover.
  • 171 Answers
SOURCE: Verbatim 1GB flash drive data recovery
Sounds like you broke something ;)
If your computer does not recognize anything when you plug it into the computer, your problem is most likely a broken contact inside the usb drive.
You should attempt to open the drive, and see if one of the four contacts on the inside of hte usb key are no longer making their way to the circuit board, and try to reconnect it.
IF you can push the connectors down with your fingers and make contact temporarily, and the computer recognizes it, try to just hold it there while you copy all your data off. Then throw away the flash drive.
Posted on Jan 25, 2008
SOURCE: usb flash drive not recognized when plugged into hub
how i can solve my problem
not recognized when plug my usb in my computer port
Posted on Jan 29, 2009
  • 11 Answers
SOURCE: usb devise not recognised
You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
Posted on Jun 08, 2009
SOURCE: My flash drive verbatim 8 gb store and go is not recognized
I have the same issue with a 4GB Store N Go, works fine on my Vista PC at home but after copying a 3.5GB file to it and then later trying to copy that file to my XP machine at work, it keeps disconnecting and failing with, "The volume for a file has been externally altered so that the opened file is no longer valid". I really wanted the file off the drive, so what I tried was using "Robocopy.exe" (in restartable mode, waiting 5 seconds between each retry) from the Microsoft Windows Server 2003 Resource Kit. Once you have a copy of this, you need to open a Command Prompt, change into a directory (CD\<foldername>) where you want to copy the file to, then swap to the USB drive and use the following command;
Robocopy Drive1 Drive2 /Z /W:5
E.g.: If the USB drive is D: and your hard drive is C: with a folder on it called "Backup" (where you want to copy the files to).. do the following;
Start - Run: CMD <Enter>
C: <Enter>
MD Backup <Enter> (If the folder doesn't already exist)
CD Backup <Enter>
(Note: Assumes robocopy.exe is in your PATH or the same folder)Robocopy D: C: /Z /W:5
This will probably take quite some time, depending on the number of files/size... but it did work for me (eventually).
Posted on Jul 16, 2009
  • 12 Answers
SOURCE: I hve a Verbatim USB Portable Hard Drive with
usualy it means that it has an error,try checking that the cables to the drive are connected properly if there all fine try shutting the usb drive off and turing it back on after 3 min.
you should turn your PC off also and restart it.
if that does not work you need to post more information about your PC and periferal devices.
Posted on Jul 19, 2009
My verbatim external hard drive has stopped working. I plugged it in to a computer at work which cam up with "power surge" the light no longer comes on and it is not being recognised in my system device...
Disassemble the external drive and install the hard drive in a pc or place in a generic external drive you can purchase without a drive inside, then you can get access to those files again. The External drive interface has failed not the drive itself.
Oct 06, 2013 | Verbatim SmartDisk Firelite Portable USB...
I have just bought a Verbatim 4GB PinStripe USB Drive. My Windows 7 computer at home will not recognise it, and nor will most computers at work (Windows xP Professional). The shop replaceed it, but the...
Hello John,
The Store 'n' Go PinStripe USB Drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
Aug 16, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
1tb Verbatim External Hard Troubleshoot
does it work on another pc ok? Do other usb devices work ok? Give me the details and I can help you solve this.
Paul
Aug 08, 2009 | Verbatim VER95327 USB Hard Drive
I hve a Verbatim USB Portable Hard Drive with 160gb/go. Suddenly I notice the blue light on the unit is blinking, and my K drive (Verbatim) is no longer showing on my computer. What does this mean?...
Jul 18, 2009 | Verbatim 160GB USB FireLite: The "drive...
Verbatim 4gb flash cant be recognised
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 02, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
Bought a Verbatim 1Gb USB Drive with some .pdf files for secure zone. I overwrote these accidentally.
usb drives dont have manuals the computer automatically detect the drive.
in saving files it is the same when you save in a floppy or other drives.
Jan 31, 2008 | Verbatim VER95327 USB Hard Drive
Electronics - Others Logo
662 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
