Question about InFocus LP 600 Multimedia Projector
LP600 No Power
We experienced a power failure. When the power was restored, the InFocus projector would not power on. We tested the power supply lines with a FlukeMeter to confirm that power was being supplied to the unit, but unitwas still inop. My question is WHERE is the fuse located on this unit? I don't want to take it apart in a random fashion.
Your help with this matter would be greatly appreciated!
  • 3 more comments
  • joebadami Nov 21, 2008
    Ditto. - Have a projector that was working great. Then after a power outage, the unit has no power, not even the "power" LED lights (it lights even when the unit is off.) It was plugged into a so-called "surge protector" but it looks like it didn't do any good. I have checked AC lines with a VOM and power is getting to the unit, but that seems to be as far as it goes.
  • Anonymous Feb 01, 2009
    No Power nor the LED lits
  • Anonymous Mar 06, 2009
    I work in a school district, and we have FOUR projectors with this problem. I contacted the company, and they tried to sell me an extended warranty.
  • welchr Mar 06, 2009
  • Anonymous Mar 20, 2009
    no power
Bitte die Elkos 100µF/16V auf der Netzteilplatine tauschen
Posted on Feb 24, 2009
Have the same problem here too, but in answer to the original question...the fuse is located immediately behind the AC plug-in. Its a 5AH 250V. In our case it tested good. All components physically appeared normal. Still not powering on.
Posted on Mar 23, 2009
We have the same problem of power to the machine but it does not come on. The projector is on a state ferry and it was in the yards so the odds that the power was turned off while it was on are pretty good. One of our engineers thought it was a fuse problem so if you could give us some direction and if we could have a manual sent to State of Alaska DOT &PF Alaska Marine Highway 7559 N. Tongass Highway, Ketchikan Alaska 99801, C/O Denise Pooler Passenger Svcs Inspector that would be great
Posted on Nov 15, 2008
The infocus LP600 won't power up
make sure the lamp door is engaging the safety switch. manually reset the lamp hours and reflash the software, if that don't work it's most likely the power supply.
May 11, 2010 | InFocus LP 600 Multimedia Projector
The InFocus LP600 won't power up
power supply. this model has a problem with them.
Mar 18, 2010 | InFocus LP 600 Multimedia Projector
LP600 - Lamp Did Not Strike
Check for shorted flat pack diode in power supply.
Feb 04, 2009 | InFocus LP 600 Multimedia Projector
Infocus lp600 not working
HI-
MAke sure that cables are properly connected, it might be that it is not getting any signal from the source.
Hope this helps
Oct 28, 2008 | InFocus LP 600 Multimedia Projector
Lp600 no power
HI
LOOKS FALUIRE OF DC POWER SUPPLY INSIDE THE PROJECTOR YOUHAVE TO GET CHECK BY TECHNICIAN
Sep 17, 2008 | InFocus LP 600 Multimedia Projector
Self Shutdown of my Infocus LP600
power supply problem. if it was overheating, it would go into cooldown mode then standby. there is an issue with the power supply, and it needs replacing. it's about $100 from infocus.
Jun 16, 2008 | InFocus LP 600 Multimedia Projector
InFocus LP600
If the counter expired, then the reset is holding both volume keys down for 10+ seconds.
Feb 27, 2008 | InFocus LP 600 Multimedia Projector
Lp600 went dead
i had the same problem with my 2 years old infocus lp600. on the mains section of the power supply board you have 4 100uF/16v and 1 4,7uF/35V electrolyt condenser of a 85 degree type. that means it will work 2000 hours at 85 degree (celsius). since the power supply only switch off the lamp in standby with no fan the power supply get hot- i think about 70 degree. so after two years in stanby it is evident that this condensers loose halve of their capacity - after switch off no new start. changing this condensers with new ones of 105 degree type will solve tis problem. and for the future - no more stanby.
Aug 14, 2007 | InFocus LP 600 Multimedia Projector
Power point conectivity
PowerPoint is a computer program. It has to be running on a PC for it to connect to a projector.
Apr 12, 2007 | InFocus LP 600 Multimedia Projector
InFocus LP 600 Multimedia Projector Logo
631 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
