Televison & Video Logo
Randy L Posted on Dec 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connection options for 46f500 hitachi
Can I connect HDMI to DVI?
Anonymous
Level 2:
Sergeant:
  • Expert 331 Answers
  • Posted on Dec 17, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
331
Questions
0
Helped
93070
Points
691
You can buy a HDMI to DVI adapter from places such as Amazon. . . See http://www.amazon.co.uk/HD-Cable-Pro-Gold-HDMI-Adapter/dp/B000PKLTQY for an example.
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Want to hook pc to tv
Connect HDMI output of laptop to input of tv. If no HDMI output look for laptop video output and get a converter for it to go to the input of tv.
How can I connect a samsung bdf5900 to my hitachi rear projection tv
Your TV is probably older and has Component, Composite and DVI connectors. HDMI is a newer connector that integrates sound. If your RPTV does not have HDMI but DOES have DVI, you can get an HDMI to DVI adapter on eBay or a computer store pretty cheap. You will need another way to get the sound from the Blu-Ray player, either external speakers connected to the player, or stereo RCA cables from the player to the TV (there will be a set of RCA audio plugs with the TV's DVI port).
Hitachi 51f510 sound no picture
select hdmi on menu or dvi/component on tv
How do i set up multi screen on my 42" HDTV Insignia
You may use an HDMI / DVI cable to connect to your computer. Next if you have windows 7 hold your windows key and hit the letter "P" (for projector) this will allow you to bring on the multi-montior feature on your computer. Make sure to select the option that says EXTEND. Please note that when connecting a DVI device you must use the HDMI IN1 (dvi) jack on the back of your TV. you cannot use HDMI In 2.
1. Turn off your TV and all connected equipment.
2. Connect an HDMI/DVI cable or DI-HDMI adapter between the HDMI in 1 (dvi) jack on the back of your TV and DVI OUT jack on the DVI device.
3. Connect an audio cable between the DVI audio IN jacks on the back of your tv and the DVI audio jack on the dvi device.
turn on the tv then turn on the dvi device.
5answers
What kind of connector do I use to connect a dell laptop to a Hitachi 42'' plasma display? HDMI to DVI or HDMI to VGA?
If the TV has a VGA connector then use a VGA to VGA cable from your laptop as most laptops have a VGA output. Otherwise use one of the other combinations that work HDMI to DVI or HDMI to HDMI..
Is there someway to hook up our Hitachi 42HDS69 to our laptop
Your computer should have a DVI port to make this possible since your TV dont have a VGA port. If your computer have a DVI port then an HDMI/DVI cable is all you need. This allows you to connect you computer or laptop to you tv through the HDMI connection on your tv.
DVI/HDMI Cable lost my pic and sound
Try disconnecting the hdmI cable and the dvr box.
Connect the cable directly to the cable input.
Sometimes the dvr boxes will cause this problem
after you connect the hdmi cable.
2answers
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
1helpful
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
