Question about Panasonic KX-T7731 Corded Phone
Call forwarding I have Panasonic hybrid system kxt7731 and I don't know how to forward my calls to my cell phone.Please advise.-Thanks
*72 +areacode & phone #
*73 to remove call forwarding
Posted on Oct 08, 2008
How do I forward calls from Panasonic KXTG4500 to my cell?
Call forwarding needs to be activated by your phone company and then set up through your account settings. The phone itself cannot forward calls. You would need a two-line phone with call forwarding features and two separate phone lines to accomplish call forwarding locally.
Feb 02, 2015 | Panasonic KXTG4500B 5.8 GHz 4-Line Corded...
FWD/DND will not cancel on KX-TDA200
Hello,still having the same problem?I can remotely configure and cancel call forward and configure your system as you want it.Contact me for help.
Mail me: omonat@yahoo.com
Make the subject be PANASONIC PBX
Aug 21, 2012 | Panasonic (KX-TDA200)
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • Oct 08, 2010 | Panasonic Cell Phones
    How do I take call
    1. To remove a number while listening to your list: Dial 07 as you hear the number, or right after hearing it.
    2. To remove a number when you are not listening to your list: Press *. Dial the number, then press *.
    3. Repeat for each number you're removing.
    4. Hang up.
    Feb 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
    Call forward to cell phone
    Who provides your dial tone? You will have to find out their code for forwarding calls to a cell.
    SBC/AT&T/Ameritech uses #72, then dial the number you want to forward to
    Jan 01, 2009 | Panasonic KX T7235 Corded Phone
    Call forwarding
    no it is not possible u should have the concerned phone/mobile in your hand for which the calls have to be forwarded
    Jun 11, 2008 | Panasonic KX-T7630 Corded Phone
    Call forwarding
    I don't know if you've got this sorted yet or if you're still looking for a solution. If you are still looking, try the following:
    From the phone the calls currently ring at, try dialling:
    7102, followed by the new extension number you want the calls to ring at. You should hear a confirmation tone and then you should be sorted.
    To cancel this and go back to normal, at the original phone dial 7100.
    Let me know if this works! :)
    Feb 27, 2008 | Panasonic KX-T7433B Corded Phone
    Cacelling forward
    To remove forwarding, lift your handset, push the FWD/DND key and dial 0. Here is the quick manual for that model - http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
    Feb 03, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7731 Corded Phone Logo
    1,038 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
