Three different wireless cards could not connect to the wireless-G Router I need to confirm WEP and check router settings.
  • Nebby31337
    Nebby31337 May 11, 2010
    What is the model of the router you are using?
    Sergeant:
    Champion:
  • 258 Answers
Maybe the pc's don't have pci wireless modem which recieves the signal from the wireless router check if you have or configured it properly
Posted on Oct 03, 2008
  • 63 Answers
Plug an ethernet cable into the router and laptop, remove the wep key. See if you can connect wireless then. If not sounds like you need to manually remove the the connection from the connection properties (DONT DISABLE THE NETWORK ADAPTOR) then see if you can connect.
I HAVE A IBM R40 WITH INTEL/R1 PRO WIRELESS LAN 2100 3B, IT CANNOT CONNECT TO MY ROUTER WITH WEP OR WPA ENCRIPTION
Check to see the wireless LAN card driver is enable and working, if not reinstall the wireless driver.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jul 01, 2011 | IBM ThinkPad R40 2897 Notebook
Tip
Enabling Wireless security on Linksys routers.....
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then unchecked “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
If this is a Helpful tip Thumbs Up is appreciated. Thank you
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
I can't connect the wireless network even it shows that the wireless connection status shows as follows: connection status: connected network duration: going on signal strength: excellent However, the...
Your router's wireless encryption setting (WEP) has been changed.
May 02, 2011 | Computers & Internet
I need a network key to confirm and do not have one HELP
Your wireless card in your computer or laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 29, 2010 | D-Link DIR-300 Wireless Router
Hi im tying to get wireless connection for my ds/club penguin. it says i need a ssid and wep key well i put that info all in and taped the test connection button but it says confirm ssid or move within...
Is your wireless router set up using WEP security? Most routers will use WPA2 by default. DS cannot connect to a WPA2 router.
Check the router and set it to WEP security to enable the DS to connect.
Dec 17, 2010 | Computers & Internet
How do I secure my network
etting up wireless security is the easiest way to prevent other people from using your wireless internet connection. Your Linksys router supports three (3) of the most commonly-used wireless security types WEP, WPA and WPA2.
This article will explain the difference between WEP, WPA, WPA2 and how to set up each of them.
Nov 06, 2010 | Linksys WRT160N Wireless Router
I have been trying to connect to the Belkin G (F5D7234) from my computer in a different room. It keeps telling me that the WEP key is incoprrect. I'm using the WPA2 code my mom gave me....do I need a...
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 26, 2009 | Belkin Wireless G Router
I can not connect my sons wii and DS to the wrt160n wireless router. nor can I find the wep code
Nov 26, 2009 | Linksys WRT160N Wireless Router
I have just purchased a new MAC and need the WEP password to connect to the internet. How do I get this password? I have a Dell router
Nov 23, 2009 | Dell Computers & Internet
Does not save wireless security settings
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
5. Restart your PC
Nov 15, 2009 | D-Link Vonage-enabled Wireless Router...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
