Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit DG6145 slim-line free-standing dishwasher problem
About two weeks ago i have added some salt for the dishwasher and i think it might be a bit too much.. as a small amount came out with a bit of water into the dishwasher. Since then when i switch my dishwasher on it seem to start the cycle but does not move form the starting point. I tried running all 4 different programs, also checked all pipes and cables and nothing is blocked or loose.
Does anyone have the same problem and is it possible to fix it myself without calling out an engineer?
Any advise greatly appreciated.
E
  • 159 Answers
SOURCE: Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Posted on Aug 06, 2007
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
Posted on Nov 18, 2007
  • 1019 Answers
SOURCE: Indesit Dishwasher DI67.Cycle phase lights(prewash and wash)flash
I,d suggest Paying The $19.99 fee, on this site to get premium assistance. You,ll have technicians queuing up to solve your problem. And You,ll Have Solutions Within An Hour.
****** Please Do Not Rate This******
This Suggestion Is Information Only.
Good-Luck Mike @ Compurepair.
Posted on Feb 28, 2008
  • 4 Answers
SOURCE: Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Posted on Apr 24, 2008
IFIXALL
  • 868 Answers
SOURCE: Indesit dishwasher di620
You may have a electric control board that is out.Sorry but this D/W is going to be full of problems.
Posted on May 21, 2008
Ids105
Try pushing door to shut it a bit harder, kids gun ****** if it is dirt doing it, apart from that it is split door for repair Re: Jeff
Apr 12, 2012 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 dishwasher, switch it on to program,
if applaince does not start draining then there is a possible fault with the door locking assembly,and the appliance thinks the door is open and this will not allow the appliance to start
Jun 28, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Dishwasher
from indesit website http://www.indesit.co.uk/indesit/_pdf/manuals/19504287203_UK.pdf
Mar 25, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
First flashing light.
I've just had this issue and managed to get it working again.
The problem is more than likely water sat in the bottom of the machine. Unload and unplug your machine. Tip it backwards by about 45 degrees, and you should notice about 1/2 pint of water leaking out of the back on to the floor (make sure you have some old towels handy).
After doing this my machine started to work again.
Nov 02, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Baumatic dishwasher accident
flush out as much as you can but you may have damaged the resin in the softener in which case you will have to replece it
Oct 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Apr 12, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
PROBLEM!
Hi try checking if the drain outlet pipe is blocked by this I mean blow down the pipe it takes a bit of puff but if you cant then there's is something blocking the water from getting out, either a blockage or the water pump not working enabling the washer to start the new cycle
I hope that helps cheers eric
Nov 13, 2017 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 40 Slimline flashing lights
the problem you have got with the flashing lights is that its the rinse aid or in need of more salt, hope thats sorts it for you
Dec 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Aug 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
115 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
