Acer Travelmate 4150 bottom third of screen is blank/white on startup. After some time will be OK often when a new program is started e.g. Windows Explorer. The fault returnes intermittantly. Using an external moniter all is OK.
Unfortunately your lcd screen is bad and needs to be replaced. Remove your screen, (don't forget to emove the battery first) get the number off of the back of the lcd and buy another one. Make sure THE NUMBERS MATCH, as close won't do. I see this problem about 2-3 times a month.
Ron
Posted on Oct 11, 2008
Acer travelmate 4150 very slow
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Jan 13, 2011 | Acer TravelMate 2300 Notebook
How to locate the Cmos battery
The CMOS battery is the RTC battery. Real Time Clock.
It's smaller version of the CR2032 batteries you're used to seeing in a desktop computer.
It's in a plastic holder that resembles a bag. The plastic 'bag' wraps around the battery.
There are two wires attached to the battery, and come out of the 'bag'.
One wire connects to the Positive pole of the battery, and the other wire connects to the Negative pole.
The wires are soldered to the Battery.
At the end of the wires opposite of the Battery is a small white connector. It's a Male connector.
The Male connector plugs into a Female connector on the motherboard.
Once you have the RTC battery pack removed, and the battery itself removed out of the 'bag', you can match up a new battery to it. Carefully make a **** in the side of the bag, and remove the battery/wire combo.
Have a competent repair person remove the wires, and connector to the old battery, and solder the wires/connector to the new battery.
Install the battery/wires/connector combo back in the 'bag', use glue to seal the 'bag' once more.
(Or you can use silicone)
The RTC Battery is on the BOTTOM of the motherboard. This means the laptop has to be completely disassembled in order to access the RTC Battery.
In the above heading it states Acer TravelMate 4000 PC Notebook. This is the TravelMate 4000 series.
There are many models in that 4000 series.
The Model Number is on the bottom of the laptop.
Models in the 4000 series are; 4000, 4010, 4020, 4050, 4060, 4070, 4080, 4100, 4150, 4200, 4210, 4220, 4230, 4260, 4280, 4320, 4330, 4330G, 4400, 4500, 4520, 4530, 4600, 4650, 4670, 4720, 4730, and 4730G.
The above Model list may not be complete.
The disassembly guide for the Acer TravelMate 4000 series will cover all of the above models.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Scroll down with your eyes to the Travelmate heading.
Go down to the third line that starts with 2700, read across to 4000.
Click on 4000.
This is a PDF file. The computer you are on now has Adobe Reader on it, which uses PDF files.
However if you do not have the latest Adobe Reader, I would suggest downloading it.
(Adobe Reader 9.3.4)
After you click on 4000 nothing will happen for up to 30 seconds. (Maybe more)
The screen will be blank. The file is downloading in the background, and after it has fully downloaded, the first page will pop up.
For additional questions please post in a Comment.
Would appreciate it if you would rate my solution.
Regards,
joecoolvette
Oct 21, 2010 | Acer TravelMate 4000 Notebook
My acer travelmate 4052 laptop hangs several time,and needs reboot, give me solution,thanks
try clearing out startup programs that run in the background if you are using windows xp go to start click on run type in MSCONFIG, look for startup tab then uncheck the items that you don't need usual items that you need to keep on running is just the antivirus program. if you are using windows vista on start search type in MSCONFIG then practially do the same thing see if it stops locking up. hit me back on the results. thanks!
May 09, 2009 | Acer TravelMate 4000 Notebook
Travelmate 290 starts then shuts down
please re install the recovery software.
Dec 10, 2008 | Acer TravelMate 290 Notebook
DRIVERS FOR TRAVELMATE 4150 nlcI
OK go to the ACER web download site and find ya exact model lappy and then Download the drivers for ya OS..
www.acer.com
OR simply type into Google search.......
Audio Driver ACER Travelmate 4150 xp download..
ethernet Driver ACER Travelmate 4150 xp download..
GL
Aug 06, 2008 | Acer TravelMate 2300 Notebook
Acer "NTLDR is missing" problem
press F10 to enter Bios and make necessary arrangemt to boot from CD rom
Jun 13, 2008 | Acer TravelMate 4150LCi Notebook
Acer empowering technology
Hi
This should be correct solutions as well as risky..
Go to start menu and click on run.. A run window opens.. U type in that window that msconfig. Another window opens.. U select the start up tab.. There u can find some programs which are run at start up.. Many are unwanted for home use.. But don't touch others because u touch others means it may be a os file.. So u disable only the compaq program.. U can easily find that program from that.. Please don' t touch others.. After disabling restart ur system then that program will not run at startup..
After this restarting windows give a warning message that the system configuration settings changed.. There u can find the option that don't show this message again when start up.. U enable that and give ok.. I think now the problem is solved for u..
Arun
Feb 12, 2008 | Acer Aspire 5100 Notebook
Please any body i need help
can't boot from CD There will be an option in the BIOS menu called "BIOS setup" or similar. ..... yes, hit f10. Save and reboot. Still goes to the screen that says :windows
Click on the link above and follow instructions,Should get ya back on line/ Please dont for get to Vote, Thank You.
Dec 15, 2007 | Acer TravelMate 4150LCi Notebook
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
