Question about Dell Latitude D600 Notebook
Don't know how to install the hard drive i bought, no directions came with it
I bought a hard drive for my D600 Dell laptop, no directions on how to install it now. Help would be appreciated
    Sergeant:
  • 268 Answers
I could explain it but I thin kit is vetter to see it vuisually so I attached this great youtube video for doing so.....:-)
Posted on Oct 03, 2008
  • Chris Callo
    Chris Callo Oct 03, 2008
    Jeez...sorry for the typo's I was a little off there haha....what it was meant to say:
    I could explain it but I think it is better to see it visually so I attached this great youtube video for doing so.....:-)
  • 29 Answers
First off you do know that if you swap out the hd with a new one you will need to reinstall windows.
If you flip the notebook over there should be some panels you can remove. check there first.
Some notebooks store the hd drive on the side and it slides out after removing a couple of screws.
Once you find what you think it the original drive it will look different as it is attached with rails that you need to remove and transfer to then new hd.
Note: if the drive you take out is ide then in some cases there will be an adapter on the end where the contact is made to the motherboard you will have to pull this off and transfer it to the new hd. Also there are 2 specific kinds of hd's one of them i mentioned which is "ide" and the other "Sata". ide has pins and sata has 2 seperate flat connectors. Sata equiped notebooks are newer and do not a chance of having the formentioned adapter. If you bought a sata drive and your notebook has an ide you will need to retutrn it to the sotre for an ide.
Let me know how things work out so i can help you more.
  • 63 Answers
There is a spot on the bottom right side of the laptop that resembles a battery slot, there is a screw in it, remove it. then gently remove the hard drive. remove the screws on the old hard drive (carefully!) and the case around it (if there is a case) keep the old drive next to the new one so u can see how to put the case around it, there is probably an adapter that goes on the pins, carefully remove that from the old hard drive and install on the new one. then install the new hard drive and replace the cover, tighten the screw (dont over tighten). Thats it, install your OS & drivers.
My dell laptop .. latitude d600 "ic" has been melted...i want to know the ic number??
The "melted" IC - this has shorted out, and something has cause this to happen, even if you replaced it, it could short out the new IC unless you identify the cause.
The D600 is an old laptop, it would be better to put your money towards a new laptop.
You could remove the hard drive and put it into an USB hard drive adapter case and use it as an USB external hard drive..
Oct 13, 2010 | Dell Latitude D600 Notebook
Changing hard drive on D600 pin configuration is different. It's supposed to be compatible, but it doesn't work
The D600 has a IDE hard drive that has two rows of pins. The only other drive for a laptop is a SATA which does not have any pins sticking out but has 2 sockets. The D600 has an adapter that goes over the pins before you install in the caddy. I do not know what you are looking at so please give me the model numbers of the two drives and I will solve the issue for you. pmgibs1@verizon.net
D600 looks like this:http://www.prudentandpractical.com/wp-content/uploads/2009/02/nbhd-ide-connector.jpg
Adapter looks like this:http://cgi.ebay.com/Dell-Laptop-Harddrive-Adapter-x-10-pcs-New-Orginal_W0QQitemZ350360450378QQcategoryZ74949QQcmdZViewItemQQ_trksidZp3286.m7QQ_trkparmsZalgo%3DLVI%26itu%3DUCI%26otn%3D3%26po%3DLVI%26ps%3D63%26clkid%3D7673905898357184421
Here are the 2 types:http://jekkilekki.files.wordpress.com/2009/06/sata-ide-laptop-hard-drive.jpg
Jun 20, 2010 | Dell Latitude D600 Notebook
I intstalled a new hard drive. When I attempt to
Make sure you have a compatible hard drive. They're not all the same.
Dec 08, 2009 | Dell Latitude D600 Notebook
Hard drive not seen in dell latitude d600 after upgrade to vista
Your hard drive may need reseating.
If it still gives error hard disk not found then you have a faulty hard drive.
You need a new hard drive and then install Windows Vista
Mar 23, 2009 | Dell Lattitude D600 Notebook
Primary hard disk drive 0 not found
Hi Kenneth,
If you just bought the laptop, then it is still covered by a warranty. Then all you have to do is contact the seller or directly to dell. This is the fastest and most appropriate way, and usually you will get one-to-one replacement (they will replace your laptop with new one). But, please make sure by contacting Dell.
Regards,
dC
Dec 12, 2008 | Dell Latitude D600 Notebook
Latitude d600
I have a Dell D600 and bought a refurbished hard drive, but no instructions to install, any help please would be appreciated.
Sep 20, 2008 | Dell Latitude D600 Notebook
Dell d600 latitude laptop
Hi
Dell Latitude D600 can only accommodate one internal hard drive. You can however install a 2nd Hard Drive as a drive module.
Check the picture below. The HDD Drive Module fits in in place of the CD/DVD Drive.
Let me know if further is needed.
Mike
Jun 07, 2008 | Dell Latitude D600 Notebook
D600
The ActivCard is a security ket that looks like a simple flash drive, and allows only the person who has it to use the computer.  Either contact the person who you got the computer from, and ask them if they have it,  or you will need to completely erase the hard drive, and reinstall the opperating system manually.
Jan 10, 2008 | Dell Latitude D600 Notebook
Just re installed windows xp on new hard drive, built-in speakers no longer functioning
Visit support.dell.com, click on drivers and downloads, and then click on the service tag option.... enter the service tag from the bottom side of the laptop... it will then display the list of drivers for that laptop.
Download and install the audio drivers and any other ones that you need.... let me know if that solves it for you. Make sure they are for your laptop model and operating system.
Oct 23, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
185 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
