Question about HP Pavilion dv6000z Notebook
Trying to help girfriend in Italy connect HP Pavilion dv6810el to the internet
Need instructions on how to set up and what is needed to insure wireless connection...
    Sergeant:
    Champion:
  • 258 Answers
First make sure the wifi is installed properly through device manager in system menu in control panel
secondly make sure the wifi is ready to connect to any through network connection in the control panel
Posted on Oct 03, 2008
Windows Vista won't let me config Arris tg862g router options
hope this help you.
you need yo reset the router, there is a reset button on the wireless router that you need to click for 10 sec after that, connect everything to your PC and follow instructions on this link bellow.
https://bendbroadband.com/residential/support/detail.asp?kb=100196
May 06, 2017 | HP Computers & Internet
My hp pavilion laptop want come on
Go through some basic steps, insure the power cord is properly connected at the wall and the laptop. Is it doing anything at all when you turn it on, any lights or sounds? Will also need to know what model laptop you have.
Nov 25, 2012 | HP Pavilion dv4170us Notebook
How to connect my HP Pavilion dv1000 PC Notebook to led tv please help me
Doesn't you have a manual to do it,it is just a simple problem if we have a picture instruction,you only need to connect with them rightly,and make a correct setting in HP pavilion dv1000.
Feb 17, 2011 | HP Pavilion dv1000 Notebook
Wireless internet connection issue
Try these steps below.
ø Try to use the website IP address in IE.
ø Disable/Configure Norton Personal Firewall from Norton Internet Security.
ø Disable Windows Firewall.
ø Disable/Enable IE proxy settings, if available.
ø Uninstall Norton by downloading & installing the Norton Removal Tool
If you are not able to connect to the internet after performing these steps then it is not any issue with the wireless and then you need to contact your ISP.
Plz try it and get back..
Regards,
Dreamkam
May 25, 2010 | HP Pavilion dv6000z Notebook
Hp pavilion a330n Internet Explorer won't connect.
check your IP Adress settings are correct for this machine,
Go to start ,then click on run,Type CMD,Then type IPCONFIG/ALL.it will show you a list of all the devices connected to your machine and your local network,
Have you got LAN & WLAN adaptors on board?
this will explain your message,
you will have to set the ip settings on each adaptor
ie LAN 192.168.1.2 and WLAN 192.168.1.3
This wiil help determine which adaptor is to be used when connecting to the network and the internet.
If your using wireless on computer to connect to the internet then run your wizard to help setup the connection
Same for the wired LAN ,use your wizard
The settings for your modem can be reset easily and your ISP will help get you connected to the net because you already have an account with them,
Cheers MISTERDJ
Apr 10, 2010 | HP Pavilion a330n (Refurbished)...
Windows 7 hp audio hp pavilion dv1000 drivers I upgraded to windoes 7 from xp and i have no sound went to alot of sites but nothing
Sir, i have HP Pavilion dv 1000 (XP operating system). Recently, i upgrade it by Window 7 but Now audio driver is not working properly now. pl suggest to solve it.----- pratik
Jan 10, 2010 | HP Pavilion dv1000 Notebook
I cannot connect tru internet, while my other laptop is working wtih this network. how will i set up this,
First we need to know exactly what you are trying to do.
You say a laptop is on the internet.
You apparently are trying to get on the internet with another computer at the same time.
If you have dial up, you will have to set up internet connection sharing on the laptop that works.
With DSL or cable, you will need to install a router to direct the signal to both computers at the same time.
Dec 07, 2009 | HP Pavilion dv6000z Notebook
Problem at no internet
no its not possible to download netcards from any where while you should just check you connection setting and try if on
Jun 23, 2009 | HP Pavilion dv9000z Notebook
Need help getting wireless laptop connected to internet
1. Go to Start, Control Panel, syetm.hardware, device manager. Under network adapters make sure your wireless is there. Note: there is a recall for HP laptops including the DV9000 because they eractically lose their wireless settings. If this is the case call HP tech support.
2. Assuming your wireless card is listed (not the 1394) and there are no red or yellow check marks we can now go back to control panel, network connections.
3. If wireless connection is not listed then click the task Create a new connection. This brings up Welcome to new connection wizard. At this point you should see a line that says to connect to a wireless network in range . . . If this line is there click this then select your SSID (network name). If this line is not there and you're sure the network switch is on and turned blue then you'll need to call HP.
Mar 23, 2009 | HP Pavilion dv9000z Notebook
Local area connection
go to start>> run >> on the black screen type: ipconfig (You must see there ip numbers)
Then type: ipconfig / renew
Close
Open internet explorer >> Go >> Tools >> Internet options >> Connections >> Lan Settings
Check the mark "Automatically detect settings"
Close
Open internet explorer...must work
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
HP Pavilion dv6000z Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
