Question about Canon LaserClass LC 8500 Plain Paper Fax
What is meaning of ng #005 and ng ##201, how to print destination phone #
When fax does not go through, want intended destination fax number on error report because ng #005 and ng ##201 don't explain anything Thank you
4 Suggested Answers
marsrover
  • 682 Answers
SOURCE: When transmitting a fax the
there is a noise or static in your phone line try to put line phone filter from radio shack(279-151)-otherwise contact phone company.
Posted on Aug 03, 2008
leroyal
  • 2120 Answers
SOURCE: What does 'NG' mean on the fax activity report
NO GOOD (USA) or NOT GOOD (ASIA)
Posted on Jan 21, 2009
FixinFax
  • 3085 Answers
SOURCE: Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
Posted on Oct 07, 2009
Fax confirmation
most printer in the market has the same standard setting for the fax.
u can set the report many types for many user's purposes, some people want to save paper, save ink/toner, so they dont need report if the fax is sent but only print report if the fax is not good(NG or not sent)
it can be set to:
report off--means report will be print out only if the fax is NG
report off+image--means report will be print out if the fax is NG + the image of the page that is not sent(so we know which page is not sent through the image)
report on+image-- every fax activities( sent or not sent) will be reported, which is not recommended
etc....
how to set is depends on your printer, just go to the menu "FAX" and look inside the menu.
Jul 08, 2014 | Epson Workforce 520 All-in-One Color...
Fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Mike
Nov 14, 2007 | Brother MFC 8300 Laser Printer
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
report lists the time and date of transmission and whether the transmission was successful
(OK). If you choose On or On+Image, the report will print for every fax you send.
If you send a lot of faxes to the same place, you may need more than the job numbers to
know which faxes you must send again.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
to help you remember.
When the Transmission Verification Report is turned Off or Off+Image, the Report will
only print if there is a transmission error, with NG in the RESULT column.
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Mar 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
A fax is not coming through and the message on the fax report says NG
This means that either the connection quality is poor, or the receiving fax machine is faulty, or your machine is.
Does it happen every time? Try to send a test fax to a number you know to be OK, and see if the problem persists. If you can't send a successful fax to anyone, then your unit may need servicing.
If the problem is with one particular destination, then you have to establish whether the faxes connect at all, and if they do, phone the other party and ask if the fax came out readable - sometimes despite the No Good message the fax on the other side looks just fine.
Sep 22, 2010 | Canon Office Equipment & Supplies
Every fax we try to send it comes up with a error tx report of "NG". What does "NG" mean and how can we fix it?
Hello.
NG means: Some or no pages sent.
Check the paper feeder to see if the page is pulling through.
Listen to see if the fax line "sounds"like it is working or if you hear dialing or not.
Hope this helps.
Mar 22, 2010 | Canon FAXPHONE L80 Laser
What does NG mean in the TX/RX log?
NG just means the fax was unsuccessful or No Good. After the NG should be another number code that tells what type of error it was. Could be busy on the other end, poor line quality, or any number of things.
Jan 12, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Our RX report for our Canon 830i fax machine lists a transaction failed (NG) with error code #0106
This error usually means you have a phone line problem.
You need to try to increase your transmission level, or check the line equalization. It could also be a problem with an echo on the phone line.
Dec 16, 2009 | Canon Laser Class 830i Plain Paper Fax
Canon LaserClass LC 8500 Plain Paper Fax Logo
302 people viewed this question
old marine
old marine
