Question about Texas Instruments TI-83 Plus Calculator
TI 83 screen
Hello, I just put in new batteries for me TI 83 calculator and there is a dark screen when I turn it on. I know that you can adjust the color of the numbers by holding down the 2nd key and up/doen arrows, butthis screen will not go away. I use it at work, and leave it on my desk, so it has not been droppped or steped on, no water damage, or anything. Before the other batteries died ( like 4 months ago) it was fine. Please help.
  • 1 more comment
  • cnwilson Oct 04, 2008
    I just put new batteries in my TI-83 and the screen is dark. I tried using the 2nd key plus the down arrow to lighten the screen but that is not working either. Please help.
  • hannaxlee82 Oct 06, 2008
    I am having the exact same issues with mine. I just replaced the batteries and the screen cannot be adjusted. The only thing I am able to do is turn it on and off. I even downloaded the guide and tried to troubleshoot but it is not working. Please help!
  • toadster13 Nov 30, 2008
    I have the TI-83 plus, new batteries plus back up...was just working for the act test one month ago, now no power, no screen, nothing.
I know your problem
Do NOT HOLD the 2nd button instead just press it once and then press the arrows hard. It will work just fine
Posted on Nov 26, 2008
Hi, it seems like I have the same issue. Please help me fix this problems. I have a test coming up and really need to use my calculator. Thank you so much!
Posted on Oct 06, 2008
This probably won't help at all, but it's worth a shot - I had the same problem and took the new batteries out then put them back in. And now it's working fine....weird...
Posted on Oct 05, 2008
TI-83 have adjusted the brightness but can't type or see flashing indicator
If the screen is not busted, adjust the contrast without going all the way to totally dark or to totally blank. Calculators do occasionally become unusable (old age, mishandling).
Mar 01, 2014 | Texas Instruments TI-83 Plus Calculator
Why is my TI-83 screen black?
If you cannot see anything on the screen, the contrast may need to
be adjusted.
To darken the screen, press 2nd and release, and then press and
hold up arrow until the display is sufficiently dark.
To lighten the screen, press and release 2nd, and then press and
hold down arrow until the display is sufficiently light
Apr 15, 2013 | Texas Instruments TI-83 Plus Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
Hello I have putted new batteries in my ca&lculator ti-83, but it won't turn on? Do I have to change the lithium battery also?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Nov 09, 2010 | Texas Instruments TI-83 Plus Calculator
Screen is dark when turned on-already removed batteries and lithium battery-is ti-83
Adjust the screen contrast. Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key to lighten the screen. If you go too far, press and release 2ND then press and hold up-arrow.
Sep 15, 2010 | Texas Instruments TI-83 Plus Calculator
My Ti-83 Plus won't come on. The screen is blank. I have just put new batteries in it. What could it be?
If that doesn't do it, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. The calculator should come on (you may have to adjust the contrast as described earlier).
Aug 24, 2010 | Texas Instruments TI-83 Plus Calculator
Cannot read screen - screen dark nocnotrast just
To adjust the contrast, turn the calculator on. Press and release the 2ND key. Press and hold the Up-arrow to increase or the Down-arrow to decrease the contrast.
Feb 14, 2010 | Texas Instruments TI-83 Plus Calculator
I just put new batteries in my calculator and when i turn it on the screen is fuzzy and dark what is wrong?
Probably nothing is wrong. Decrease the darkness of the screen
1.Press [2nd] key and release it
2.Press [ArrowDown] key and release it.
3.Repeat the two steps above in sequence until screen lightens up. You may have to repeat the cycle several times.
Hope it brightens your calculator screen and your day also.
Oct 13, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 screen is black
The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
Aug 29, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
198 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
