Question about Amana Refrigerators
The refrigerator is not keeping tempurature. Freezer is working fine
    Scholar:
  • 142 Answers
Either the freezer fan has stopped blowing air or the defrost timer has stopped and the airways to the fridge are clogged with ice. Only the freezer gets cold in a refrigerator. The fridge part gets cold by cold air being blown through air passages from the freezer. Good Luck!!
barneyluc
Posted on Oct 03, 2008
Freezer not working when its cold in the garage.
Where do you keep the fridge? If you keep it outside then most likely the condensor coils in the freezer may be freezing over and the only way to fix that is to keep it above 40 degrees outside the fridge.
Jan 18, 2017 | Refrigerators
What is the best tempurature to set the fridge at, and the freezer at?
Standard is ::
Refrigerator @ 40 degrees F
Freezer @ 0 degress F
Charlie
Mar 26, 2011 | KitchenAid KBRS22KG
Unit is about 5 years old have had tech. come in and looked at it because it would not stay on. The temp. would drop. He stated that the compressor was fine. He did something in the top inside unit by the...
NEXT TIME IT STARTS TO WARM UP, OPEN THE FREEZER DOOR AND TAP OR THUMP THE TEMPURATURE CONTROL. IF THE UNIT TURNS ON THEN I WOULD BET THE COLD CONTROL IS BAD. ORDER PART NUMBER 67003000 FROM YOU PREFERED SUPPLIER OR REPAIRCLINIC.COM
Mar 23, 2010 | Amana ARB2557CSR / ARB2557CSL Bottom...
Maytag MSD2651HEQ frige not cooling; can hear/feel fan blowing
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Maytag MSD2651 HE Side by Side...
The refrigerator part is not working
It sounds like the Freezer Fan is waring out. This fan supplies circulation for the freezer as well as the refrigerator. When the motor wears down the rpms are reduced to a point that it will keep the freezer cold but not the refrigerator
Jul 11, 2009 | Refrigerators
Tempurature Goes Up
sounds to me like your thermostat is bad
Jul 10, 2009 | GE Q Series GSS25QGT Side by Side...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Refrigerators Logo
195 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
