Question about Intel Motherboard
Cpu not starting up....power 2 cpu from smps is ok..
Hello
i m debasish..from india bbsr orissa.
power 2 cpu from smps is ok..but cpu is not starting up..i.e the processor is not starting up....can u please tell me the the hdd led and hd reset connections in detail...
Thank You..
  • velut_umbra May 11, 2010
    Need more data than that. Board model, for instance. Have you tried the power supply in another pc?
  • 24 Answers
Hi most of motherboard power on pin is 6 and 8 just short these two pins once if mothernoard starts it;s giving display else check ram or smps otherwise motherboard faulty.
Posted on Oct 13, 2008
Model no-l1506 when monitor power on then on monitor scren coming osdlocked
Hold down the Menu button for 10-20 seconds until you get a message saying "OSD Unlocked". And it will better to change all the switches.because some time may be any switch was dymaged.
It is my practical knoladge
Answered by Bijay ketan mallick (orissa,bbsr)
Sep 19, 2011 | HP L1506 15" LCD Monitor
SMPS is faulty,needs to be replaced,i am located in orissa,INDIA.
before replacing check what part is not working like capacitor or anything, it happens that your smps ok but due to faulty parts it dosen't supply sufficient power to respected components.
Feb 26, 2011 | Office Equipment & Supplies
Mother board fault
NO problem about..... the mb..
its ok.. The problem may be with SMPS or motherboard...
Contact the from where you buyed your PC..
May 30, 2010 | Mercury P4VM800M7 Motherboard
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Nov 19, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
CPU does not turn on..everything is plugged in..power cord is plugged into a working socket. what are my options?
its 2 cable that need to be plugged in from the power suppley, the wide cable and a 4 stick cable. both to the mother board. also you need to connect the fan cable to the mother board. how do you know that the processor doesent start ?
Oct 26, 2009 | Computers & Internet
No beep,No Display on my monitor,only CPU heatsink fan is moving
hey
there might be problem with SMPS also. I mean there is one signal comming from SMPS - Power Good
if that singal is not comming then machine shows this kind of symtoms.
To check Power Good from SMPS -
Requirements ->
a) small wire/ pin
b) Multimeter
Procedure ->
1) Disconnect all power supplies going OUT from SMPS.
2) Locate the Orange Wire , Green Wire, Blackwire
3) Now insert small pin / wire into Black + Green wire (Make them SHORT) and provide power to SMPS --> SMPS will get started.
4) Now check the Multimeter rating for Orange wire --> it should not be less / more than 3.3 - 3.6 volts. --> If it is less / more then there is problem with your SMPS and you need to get it repaired.
5) In india it will take near about 100-150 Ruppes to repair SMPS.
alternate ->
You can replace your SMPS with other working SMPS (best option will be your friends system) and check whether same symptoms occurs or not.
Other Damedge -
If SMPS is working fine then there must be problem with FEW SMDs available on your motherboard. For this repairing in INDIA it should not cost your more than 600-700/-
May 29, 2008 | ASUS K8V-MX Motherboard
Computer power problem
For solving your problem do the following:
1. Check that the power cable is connected properly to the monitor
2. See that the SMPS of the CPU is working
3. Check that the power output from the SMPS is upot 12V
If not change the SMPS it may be due to failure of SMPS.
Let me know if your problem is solved and rate me as FIXYA!
May 13, 2008 | Compaq Presario 5000 PC Desktop
Cpu/motherboard dry solder prob?
Check the capacitors on the motherboard, chances are good one or more are fried.
Feb 12, 2008 | Compaq Presario 5000 PC Desktop
No power
1. Please check with the power supply of pc from a/c plug. 2. if power supply is ok then ensure that the input poewer cord is at right position in behind of cpu. 3. If you are using old type power supply (which do not autumatically turned off by operating system) then there is problem with power switch or SMPS. 4. If you are using advance power management (generally used in now-a days computers which is automatically turned off by O.S., then there may be a problem with power pin that is connecting thae mother board and power button. Shut down your computer and open the cpu chasis and tighten the pin and ensure that it is properly inserted (the location of the pin is near hard disk lid pin, power lid pin). 5. If this pin is ok then check with pconnecting wire of pin and power button and also the power button. 6.Then turn the computer on. If it does not work then check the power connectors from SMPS to mother board are properly installed and inserted. 7. If power connector is ok then there is posssiblity of problem with your SMPS (power supply) of computer. 8.Generally due to heavy load of power and long usage the condensers of smps get mailfunctioned. Take the smps or computer to a local hardware expert.
Aug 25, 2007 | Compaq dc7100 Small Form Factor (PJ361UA)...
Intel Motherboard Logo
109 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
