Question about Toshiba e-Studio 350 Copier
CALL FOR SERVICE estudio350
When i try to print the paper gets jammed in the feeder and then it beeps and a message comes up with call for service. Is there a way to by-pass this problem? Many thanks
The registration sensor could have paper dust on it
Posted on Oct 14, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
You can by-pass by putting the paper on hte glass and making the copies.
there is most likely a pice of paper or paper clip in the feeder
Posted on Oct 03, 2008
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Epson cx3200 printer has printing problem
    Hello cockie ,
    You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
    If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
    It may also be helpful to try running a printer nozzle check.
    See the following message problems and solutions:
    Error Message Probable Cause No color or black ink cartridge - - >
    Press the Color Copy button to install a new ink cartridge.
    The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
    Press the Color Copy button to begin replacing the ink cartridge.
    The indicated cartridge is out of ink Ink cartridge error - - >
    There is something wrong with the ink cartridge. Paper jam or misfeed - - >
    Press the Color Copy button and clear the paper jam by hand if necessary.
    Paper is jammed. Press the Color Copy button to clear the jam.
    See the User's Guide for more troubleshooting tips.
    Paper out - - >
    Load paper in the sheet feeder and press the Color Copy button.
    Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
    Close the scanner unit.
    Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
    See your documentation and call Service if necessary.
    Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
    Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
    Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    The printer is constantly sending a message- 'paper jam'
    HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
    Issue
    During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
    Solution
    Use the following instructions to clear a paper jam from the product:
    Step one: Check for and remove any loose paper from the In tray
    Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
    CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
    Step two: Clear the jam from the back of the printer
    Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
    Remove the rear access door to clear the paper jam
    1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
    Figure 1: Removing the rear access door
    Rear access door
    2. Gently pull the jammed paper out of the rollers.
    WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
    3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
    Remove the two-sided printing accessory to clear the paper jam
    1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
    Figure 2: Removing the two-sided printing accessory
    2. Gently remove any jammed paper.
    WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
    3. Press the button on top of the two-sided printing accessory to open the door.
    Figure 3: Opening the two-sided printing accessory door
    4. Gently pull the jammed paper out of the rollers.
    5. Close the accessory door.
    6. Reinstall the two-sided printing accessory.
    Step three: Clear the jam from the automatic document feeder (ADF)
    1. Remove the document feeder tray from the product by gently pulling it.
    2. Lift the cover of the automatic document feeder by pulling it outward.
    Figure 4: Lifting the cover of the automatic document feeder
    Automatic document feeder (ADF) door
    3. Gently pull the jammed paper out of the rollers.
    WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
    4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
    Step four: Verify that the print carriage can move freely
    Follow these steps to try to move the print carriage.
    CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
    1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
    2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
    3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
    4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
    You may have to reach through the output paper tray to access the print carriage.
    5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
    6. Press the On button to turn on the product.
    Step five: Reload and test the printer
    After you have removed the jammed paper, make sure the product is still functioning properly.
    1. Reload the product with plain paper.
    2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
    Step six: Service the printer
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Dec 30, 2009 | HP DeskJet 3745 Printer
    Bulk feeder keeps jamming
    It might be the tray Feeder not placed properly or the printer needs a service if not done in the last six months. Contact to your nearby Repair shop and Service centre.
    Thanks
    Scott
    Feb 06, 2009 | Kyocera FS-4000DN Laser Printer
    Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
    Hope this helps....
    Explanation of the paper jam message
    A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
    NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
    Clearing the jam
    To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
    Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
    NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
    For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
    NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
    Remove any jammed sheets of paper you find and try printing again.
    Dec 12, 2008 | Lexmark T640 Laser Printer
    Printing problem
    there is a mis-alignment in the paper feeder, get it realigned by the technician, or just service ur printer.nothing to worry.
    Jun 04, 2008 | Office Equipment & Supplies
    Epson Photo RX600 error messages
    Hi.
    Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
    Goodluck... Fixya me...
    Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
    Brother MFC paper jams on one side
    Honestly? Unplug the machine...REMOVE THE DRUM UNIT!!!!! and other parts not locked down. Turn it upside down and shake it lightly to moderately. You can also try holding the lever forward while you do this. This has worked for so many machines you would be surprised. You might be even more surprised what comes out. I have seen pens, pieces of ceiling tiles, wire clippings, Matchbox cars, and grape jelly (I didn't ask).
    Dec 16, 2007 | Brother MFC 6800 All-In-One Laser Printer
    Unable to print properly keeps printing on one line
    Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
    Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
    Toshiba e-Studio 350 Copier Logo
    106 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
