Philips convergence Thanks for the info re the resistors. You mentioned that all 3149 to 3160 were the same 1W 6.8ohm. I have checked and found that the original 3156 is different to the others. 3156 sits next to 3164 and is the same as that. I cant see any description on it but it is the same size as all the others but is light blue in the middle and it grey on each end. Should I still replace this with a 1W 6.8ohm? What else could it be? Thanks again for your time.
  • lukev Oct 06, 2008
    Hi Slinteriors,
    The two resistors appear to have some writing on them but it is not legible. They do not have any colored bands on them however as I mentioned previously they are grey on the ends (approx 1/3 of the resistor) then light blue in the middle. I cannot see if they are 6.8 ohm. After checking all the resistors in the television, it appears these are the only two of this kind. Thanks again.
  • 8,617 Answers
What are the color bands on those two resistors they should be Blue, Grey, gold and gold if they are 6.8 ohm
Posted on Oct 03, 2008
  • Sonny Berry
    Sonny Berry Oct 06, 2008
    often the 6.8 ohm resistors have a code on them 6R8 1w J which means 6.8 ohm 1watt 5% Can you distinguish if that code is on those resistors?
We just recently bought it used and had it moved. Now there is a constant shadow and on words its even worse. I can't get into the program to align it manualy. Can I find a way to do it myself or do I need...
Most likely a repairman - but review the info below to determine
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 28, 2009 | Philips 55PP9401 55" Rear Projection...
I have a convergence problem on by philips 60 pp9202 tv. How do I repair this?
See link for more detail between
charge http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | Philips 60PP9202 60" Rear Projection...
SONY Convergence problem
You probably need to get a Sony TV Convergence repair Kit. More info can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find convergence repair kit information here.
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 06, 2009 | Philips 46PP9302 46" Rear Projection...
Remote will not adjust red convergence/multi-point horizontally
check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Jan 17, 2009 | Philips 55PP9352 55" Projection Television
Philips convergence
They could be wirewound resistors or perhaps thermistors or thermal fuses or even special components.
You really need to refer to a service sheet or repair manual.
Nov 07, 2017 | Televison & Video
PHILIPS MODEL # 46PP93 0217 40 INCH.
It may be the fluid in the CRT or the convergence chips are bad.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Sep 22, 2008 | Philips 51PP9100D 51 in. Television
Convergance borard
the convergance is located on the ssb board part #313503712271 but it might be cheaper to replace the convegance amplifiers and the resistors. the amps are STK392-120 the resistors are 6.8 ohm 2watt and 10 ohm 5watt. there are 8 of each starting with location 3149 to 3166. check them with an ohm meter to see which ones are open. there may be visible scorching of the bad resistor.
Feb 08, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox Projection Convergence
You may have had another problem if the screen was wavey. This is typicaly caused by the opto chip. Check www.magnavoxhelp.com for more details.
Jan 12, 2008 | Philips 9P5034C 50" Rear Projection...
Phillips 60PP9202 Convergence Problems
The two convergence IC's are generic part# STK392-120 (Philips original part# 932212344682) The two resistors are sitting side by side (6.8 ohm 2 watt)
Sep 15, 2007 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP920217F Convergence Problems
replace ic chips pt# stk392-120 or stk392- 150 and there are 12 resistors located near ic clips pt# 6r8 ( color code blue - gray - gold - gold ) board location no#s 3149 thu 3160 if you look close you may find two resistors discolored as i found on my convergence circut board , also use heat sink compound on new ic chips , take your time to mark all wire connectors going to board from tv , also use .022 dia gage rosin -core solder and a 15- 25 watt soldering iron you may have to adjust the red - blue convergence afterwards my tv set is 3 yrs old also ( thanks holbert )
May 03, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
