Will not turn on
Would like to continue where I left off last night with Marked the helper
  • cldgordon Oct 03, 2008
    Yes
  • cldgordon Oct 25, 2008
    It is a Smith Corona /WordSmith. Model Number KA 13.
    It does absulately nothing when I turn it on, light wont even come on.
    and does nothing. Have tried different power outlets and to no availe.
    Cora.
    Scholar:
  • 183 Answers
Need to know what make and model machine, and what it does when you turn switch on.
Posted on Oct 24, 2008
How do I bleed an empty brake system on a 1997 Tahoe 1500
Fill the reservoir with brake fluid. with a helper pumping the pedal start at the right rear. Open the bleeder and tell your helper to push down. Once the pedal is down the helper will yell down. Close the bleeder and tell your helper up. your helper will then let up on the brake pedal. Continue until fluid comes out with no air bubbles. Proceed to the left rear and repeat. then the right front and finish with the left front.
Make sure to keep on eye on the fluid level and keep topping off as necessary. You may have to repeat the process more than once.
Jan 31, 2016 | Cars & Trucks
How do i fix my dashboard lights on my 1986 chevy nova?
Turn the light switch on and check your tail lights. Back then the tail and dash lights work on the same circuit inside the headlight switch so if one was out so was the other. If this is the case you need a new headlight switch. If not, there should be a fuse in your panel marked "instr". that's for the dash lights. Hope this helps.
Oct 31, 2011 | 1986 Chevrolet Nova
I have a 52"
Need model number and blink code at time of defect.
Feb 16, 2011 | Panasonic Televison & Video
2002 Jetta Dead radio
Yes it could be a blown fuse most of the time but check the fuse marked radio in the fuse box
Mar 06, 2010 | 2002 Volkswagen Jetta TDI
2006 Impreza sti- i get continuous knocking while in reverse
does it happen turning both directions? AND...does it happen turned the same angle in forward gears? Can you feel it in the pedals, floor, your seat or through the shifter? You may want to grab a helper and take them to a business/industrial area that has an empty parking lot and have them stand out side the vehilcle while duplicating the symptom. See if you can roughly locate where the sound is coming from. e.g. right front, left front. under center of vehicle. Your helper may need to walk or run near the vehicle while backing to be closer to the noise while it occurs.
Oct 14, 2009 | 2005 Subaru Impreza
Park lights and dashborad lights went out whats wrong?
your fuse panel is on the left side of the dash. open the driver side door and look at the side of the dash you will see a panel door thats marked fuse panel. you can't miss it.
Mar 13, 2009 | 1998 Plymouth Breeze
Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Jan 04, 2009 | Freezers
Left door open on freezer last night and now it wont work
turn it off for a day or two let it defrost and then turn it on. it just has frozen up the coil, or the compressor has heated up cause it was working to hard turn it of for a cople of hours to let the compressor cool
Jan 04, 2009 | Frigidaire FRT21P5A Top Freezer...
Fixya.com
repost with original problem and what you have tried
Oct 03, 2008 | Smith Corona Office Equipment & Supplies
Washer isnt turning on
Ok lights out and no power. Now according to the model we all have trouble with a series 70 top load washer? If you have no power I would change the timer. If you have time on the console is two side clips that pop off with a flat head screw driver, these are on front left and right edges. This will reveal two philips screws. Once out the top flips back. There should be a diagram for power to trace from the cord. Just for starts measure volts ac where the cord enters the machine. Now this will take logic and patience. Note which wires are on the same side of the power, neutral and hot. With the machine unplugged check continuity according to the chart that shows time and function. This is not too easy as the writing is small, the wires are usually numbered and marked on the insulation. If you find one connection with out continuity when there should be you have found the power issue! You don't need power for this as it is mechanical and contact is contact.
Sep 09, 2008 | Kenmore 22422 Top Load Washer
jasbo
jasbo
