Question about Ryobi Measuring Tools & Sensors
Ryobi TS 1341 Can't open to operate
I was given a used TS1341 Ryobi Miter Saw. I cannot figure out how to open blade to operate. I've seen on different forums its supposed to have a yellow knob on the back, I don't see any. There is a threaded hole on the back of the saw, to the upper left of the torsion spring. Could this be where a knob is supposed to be? Other than that I can't for the life of me figure this out.
jyackle5
  • 8197 Answers
SOURCE: cannot find parts for ryobi 15in miter saw
Go to this site for parts. You will need model number though.
http://ryobitools.arinet.com/scripts/EmpartISAPI.dll?MF
Posted on Dec 16, 2008
riverotter
  • 58 Answers
SOURCE: changing the saw blade on a Ryobi Mitre saw
Usually there is a piece of metal around the motor you use to lock the motor by pushing it in then you can use a wrench to loosen the bolt holding the blade on. make sure you put the new blade in the same way the old one is.
Posted on Jan 22, 2009
SOURCE: saw blade broke. motor won't run after changing
It would have cost more to have Sears fix the saw than I paid for it, so I got my meter out and by checking the voltage drops across all of the electrical connections in the saw , I determined that the on / off switch was defective. This switch is the same switch used to turn the lite on and off, so I took the switch out of the lite and used it in the saw. I ordered a new switch for the lite and will install it when the new one comes. Thanks for your interest and help. fletcher1
Posted on Jul 21, 2009
SRF518
  • 232 Answers
SOURCE: Ryobi 10
go to eurton electric from california for replacement switches.
Posted on Oct 16, 2009
ftw1952
  • 10319 Answers
SOURCE: I have a question on a simple repair on a Hitachi
A screw simply fastens the spring on to the housing of the body unless for some reason its missing
Posted on Mar 22, 2010
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
Ryobi TSS100L blade guard spring
I think what you are refering to is a circlip washer , and can only be
fitted with ( CIRCLIP PLIERS ) do you know any Michanics or Engineers as they are bound to have a set in their toolbox ,on the other hand you
can buy them. What they do is work in the opposit way normal pliers do
when you squees the handles together the jaws open,therefor opening
the (CIRCLIP ) and allowing you to place it over the pin and into the
recess. Hope this has been of some hellp goodluck T.C.
Mar 29, 2013 | Ryobi Saw. 13 Amp 10 in. Sliding Compound...
I just bought a brand new Ryobi saw from a neighbor but he couldn't find the manual. TS1141L 7 1/4" miter saw how do i get one?
Try this site. http://powertool.manualsonline.com/manuals/mfg/ryobi/ts1341.html I could not find your exact model. If this is not close to what you have then there are many other models to chose from. Just click on "ryobi saw" above the manual to see the rest of the models. You should find something very similiar. Thanks and please rate.
Sep 05, 2011 | Ryobi 10 In Miter Saw With Laser
Rec'd a RYOBI 10" miter
I would remove the one already installed and take it to different dealers or large electrical suppliers to match it
Oct 02, 2017 | Ryobi Garden
Ryobi compound miter saw Model TS1341 To rotate the table assembly on the base to change angle of cut is very difficult. The table assembly and base are aluminum that slide or rotate against each...
you might try some silicone lubricant spray (available at auto supply) the stuff is very slippery. spary a little on the underside parts that rub on one another, try not to get any of the silicone on the top parts of your miter box as it will get on the wood that you are tyring to cut and it will leave a stain.
Mar 22, 2011 | Ryobi Saws
Is there a way of locking the blade and which way do I turn to remove the blade on a Ryobi TS-200 miter saw.
I put a long handled screwdriver through the teeth and brace it against the upper guard in the correct rotation, then the screw in the center of the blade will be reverse thread, turn to the right to take off.
Oct 17, 2010 | Ryobi Saws
Loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Measuring Tools & Sensors Logo
200 people viewed this question
Top Ryobi Measuring Tools & Sensors Experts
JOHN LAPIER
Vuk B
ray gallant
Are you a Ryobi Measuring Tool and Sensor Expert? Answer questions, earn points and help others
