Question about Durabrand DWT2704 TV
Powersurege damage there was a series of power surges during the recent power outage. Our TV was turned on during that time. Now we have no picture just a blank screen and just a buzzing sound. I need to know if it can be repaired.
  • 146 Answers
Anything can be repaired. But the cost can be a problem. The most commond thing to happen is the power supply gets knocked out (fixable problem), but I have seen the whole tv get knocked (not cost effective) out as well. The only way to find out is to let a repair shop look at it.
Posted on Nov 19, 2008
A power outage last night. The tv was off, now it wont turn on. A blinking timer light on the front of tv is on.
Always include model numbers since problems are sometimes associated with particular models. This may be a sign that a line surge during power fluctuations has damaged the power supply. There are a least two supplies in any modern set; a small supply that provides voltage to the remote circuitry and this one is always on. The second supply is the main one that is turned on when the set is to be used. Reluctance to turn on is often a signal that certain components (capacitors) are failing in the main supply and they will continue to degenerate. Try pulling the plug and leaving the set overnight without any power. If a circuit is only 'confused' (locked up) this should reset everything. If it still will not turn on, then either the small supply for the remote circuitry was damaged during a surge or that the main power supply is not responding to the power on command.
Jun 09, 2011 | Mitsubishi Televison & Video
After a power outage tv wont turn on
I get these in the shop all the time, usually when there is a "Power Outage" there is also a "Power disturbance" meaning Spikes, Surges, Transients and the like, are generated at "Drop Off & Reconnection times" These disturbances will Damage anything connected up that has NOT been turned OFF, or unplugged. I then will, at the Clients, behest, write an insurance report, so the client may claim on their insurance policy. As this is something that is usually covered, after all, it was, and is an accident. Always note down any times when events such as this happen, this adds credence to all claims.
You see what happens is when the power is cut off and then reconnected, the doing of that causes all sorts of Sparks, Surges, Spikes, and Overvoltage Transients, ALL of which, will damage the power Supply, and often migrate past that too, and "Get into" the "Other" circuitry, and destroy it too.
This also happens during lightning storms as well, it is prudent to unplug things at these times too. Now many things are indeed resistant to these problems described however, they do not always afford protection 100% of the time.
Feb 24, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Green light is on ...white noise sound but no picture
This TV finds the connected input sources
automatically for AV1, AV2 and Component 1-
2. It is presumed that RGB and HDMI/DVI
sources are connected.
Check your setup to see if the audio is turn off but if you have a clear picture you should have sound.
Time to call a TV Tech if you are not going to repair the unit.
Jul 11, 2009 | LG 42PC3D 42 in. Plasma Television
Electricity went out and not flat screen will not come on
Hi, this was a very powerful surge that has occurred during the power outage. the surge has fried the power sector of your set. you will need to replace the damaged power board/flyback in this case. this will restore the normal power flow in the set.
Jun 18, 2009 | iLO IWT3206 TV
No picture (black screen); making popping/crackling sound
there is a possibility that the semiconductor in power supply side damaged due to electrical surge. more likely the STR IC of Diodes.
Jun 01, 2009 | RCA P61960 61" Rear Projection Television
After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
May 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Gateway plasma tv no picture.
A start-up surge after an outage may have affected the power supply.
Dec 30, 2017 | Gateway LCD30TV Television
RCA Scenium 44" HD44LPW62
it does not sound good take it to tv shop intermitten shut down or dead sorry
Apr 03, 2009 | RCA Scenium D34W20 34" TV
Picture shifted and ghost image
Try using an input other than the tuner. I.e a DVD player or game system on the front inputs. If the picture looks OK on the other input, your tuner is damaged and will need replaced, if it looks bad also, try unplugging the TV for 5 minutes and then go through the setup process in the menus. If this fails seek a repair shop.
Sep 08, 2007 | Toshiba 34HF81 34" TV
Televison & Video Logo
55 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
