Question about Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent
HI, I have a Bosch tankless water heater with electronic ignition and no pilot light. The heater will work great for a week or so then it will cut off for no reason and flash P2 in the readout. If I restart the heater a few times it will reset and work for a few more days and them we do the same thing all over again. "P2" is suppose to mean the incoming water is too cold, but that hard to believe in the middle of summer. Any ideas? Thanks
  • Tim Hamlin May 11, 2010
    P2 is a programing flash on the board. It has nothing to do with temps. If this is happening all on its own, then you have a control board problem. If this is happening when your trying to reset the heater, then the error code is different.
  • 25 Answers
Actually E2 means the water is too cold. P2 is a computer program setting.
Check the connection of the temp sensor itself, maybe its broke on the inside if a new temp sensor didnt fix the problem.
Posted on Jan 19, 2009
  • Tim Hamlin Jan 19, 2009
Bosch 1600 h not lighting pilot light
If your getting a spark the generator should be ok I would clean the pilot injector and re try
Nov 16, 2014 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch Confort S 13 BP tankless water heater won't ignite, It clicks but no gas going thru valve
The S 13 BP is a simple unit that does not have a pilot light. It uses electronic ignition on demand, which is what you hear clicking. If there is no gas going through and you've verified there is gas to the inlet, then it has to be the gas control valve.
Feb 01, 2013 | Bosch & Tankless LP Hot Water Heater
Cannot find pilot light on my bosch GWH635ESL, help!
Call Bosch
Gas Products Technical Support: 800-642-3111
That model number is only shown at one website, and that model number is not shown at Bosch.
Open following link for Bosch:
http://www.boschwaterheater.com/BoschHotWatercomHome/GasProducts/tabid/331/Default.aspx
Search of Bosch for that model number shows no result.
Some water heaters do not have a pilot light. Instead they use hot surface igniter rod that glows red hot
The igniter rod ignites the gas after solenoid valve opens and gas flows to combustion chamber.
The igniter rod and heat sensor have to be operational, and have to be positioned correctly for ignition to take place.
If igniter rod is not working, or if heat sensor does not detect flame, then gas solenoid valve shuts down and water heater does not heat water.
Sep 03, 2011 | Bosch Water Heaters AquaStar - Tankless...
I have a bosch system 21e it is, i was told to ignite the pilot light, can you tell me how this is done?
Consult your owners manual.
http://www.bosch.com.au/content/language1/downloads/70R_UserManual1023.pdf
Heres a new one if you don't have or lost yours. You can't, you got bad advice. tankless system don't have a running pilot light. They operate by detecting water flow and then turning on. Many also state on the lighting instructions to NEVER try and manually light the pilot. Try Bosch tech support. Lowes sells Bosch heaters and they might be able to help you get the support number faster. Hope this helps but please don't go sticking a flame inside there.
May 16, 2011 | Bosch & Tankless LP Hot Water Heater
Pilot light goes out randomly on 6 year old Bosch Aquastar tankless water heater. When I restart it it may work for a day then goes out again.
The pilot light can be blown out just by the main gas being ignited especially if the pilot flame is a little weak. Some times a bit of grit gets into the pilot nozzle reducing the flow and hence a weak flame. Try cleaning the piolt jet nozzle with a fine piece of wire. You may have to dismantle the jet nozzle to clean it properly.
Aug 30, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
May 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch tankless GWH 1600 H NG won't always ignite. The igniter sparks, but doesn't always light the gas. It just clicks. When installed it lit every time, now it takes more and more tries to get it to...
The manual says to hold a match near the pilot while the ignitor is trying. It says that if the unit lights the pilot orifice may be dirty or clogged. Then the manual says to check the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
Let me know the status ...Kevin
Mar 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent Logo
229 people viewed this question
Top Terminator Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Terminator Kitchen Range Expert? Answer questions, earn points and help others
