Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell dial thermostat
Stumped. Honeywell dial type wall thermometer giving no reading on face. No batteries to replace (hardwired), tripped the circuit breaker, checked furnace switch, nothing worked. Still blank.
Unit 5 years old, no a/c just gas heat. Decided to do a test drive when I noticed the problem. Worked fine last winter.
Whats going on??
5 Suggested Answers
  • 168 Answers
SOURCE: honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Posted on Feb 03, 2008
muttandjeff
  • 359 Answers
SOURCE: Honeywell dial theromostat.
you need to check the furnace itself for , locate the 24 volt ac transformer inside the unit and see if it is fused some are some not , check to see if you have 120 volt ac in from the source and 24 volt ac out , sounds to me as if you have lost the 24 volts ac which powers the thermostat as well as the furnace pay close attention as to how you remove the wires and make a diagram and you should be able to replace it yourself , once you get it uot goto a heating supply place in your area and let them match it up and this should be a fix ya
Posted on Dec 31, 2009
shastalaker7
  • 1515 Answers
SOURCE: Our Honeywell programmable thermostat is
Good Morning, and yes you said it. Anytime a stat doesn't come on when it is set for a call for heat or cooling, the sensor on the subbase of the stat has lost its ability to sense the correct temperature. I have seen mechanical stats last as long as 25 plus years, but that's truly amazing for a digital stat to last that long. Yes, replace the thermostat. I don't know what kind of system you have, but if its a gas furnace with an a/c, the wiring will look like this. You will have terminals marked R, Red, for the 24 volt hot wire, G, Green, Y, Yellow, and W, White for heat. Going back to the red wire, it should have RC and RH on it. There will be a normally red wire connecting the 2 terminals.The Red wire coming in can connect to either one, as they are all together. The new stat will come with the new Red jumper wire attached. So, if you do have a gas heater, this is very easy to install. The only terminals you will need to use are RH to RC for the incoming red, Y, G, and W for heat. Y is for cool, and G is for fan. Very easy. Now if you have a heat-pump, they have many more terminals and can be a problem wiring them. If you have gas, forget the heat pump. I wont confuse you by going there. If it is a heat-pump, contact me in the comment box to let me know, and I can help you there also. Get a new stat at Home Depot, Lowe's Hardware, or O.S. Hardware. You want a 5 day, 2 day programmable Heating and cooling thermostat, 24 volts.It will have everything you need. See if it takes batteries for the display, they may not come with those, it will say on the box. Turn off your power to heater, so you won't short out the new one.They come in 2 sections, first the stat that just snaps on, and the subbase that is screwed to the wall. It will have the wiring terminals on it. Remove a couple of screws and loosen wires and remove. Be sure you write down how the wires go in case they used different colors, you never know. You will be all set. Store the manual in a safe place for future use. I wish you the best.
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
PS, Please rate me on this :))
Happy Holidays to you and family!
Posted on Nov 23, 2010
Testimonial: "I hate spending money needlessly replacing items that may not be the problem. Thank you for confirming my suspicions."
  • 1015 Answers
SOURCE: My honeywell thermostat is asking
The first thing i would do is to make sure the t-stat is good.One easy way to do this is to remove stat cover then remove the screws that hold it to the wall. Disconnect t-stat wires making sure you note location. There should be a red and white wire for heat so put these two together and if your furnace comes on then the stat needs replaced. If it does not you need to check further to make sure you have power to your furnace.If the furnace does come on with these two wires together the furnace will run non stop. Hope this helps you. Thank you
Posted on Jan 12, 2011
I have a honeywell focus pro 6000 temp in house doesnt change unit runs constatly. thermostat says 78 thermomiter on other end of house says 72. changed batteries
It's possible you have a lot of dust build up inside the stat. If it has batteries remove face from wall and blow out. Take outside to see if temp will change. Plug the hole in the wall where the wire comes through. If all fails, replace. Turn power off, take wiring picture, replace, turn power on. Good Luck!!
Apr 30, 2017 | Honeywell Heating & Cooling
Honeywell t6360
Turn system off then back on and see if it is working. The manual can be obtained at:
http://historical-products.ecc.emea.honeywell.com/2008_1/pdf/en0r8281uk07r1204.pdf
There is not enough information to give you any more help. What does "Dial not working indicate", the Honeywell T6360b1028 is a heating and cooling thermostat with the potential of having a heat anticipator.
Mar 16, 2014 | Honeywell T6360b1028 Room Thermostat
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
Honeywell Thermostat RTH7400D
The thermostat will not cut off the A/C until the thermometer reading gets to 76.
If there is not a heat source near/behind the thermostat which is causing the thermometer to read higher than actual room temperature, it sounds like the thermostat thermometer is out of calibration.
There are ways to calibrate it, but much to involved to go into here.
One solution is to just set the thermostat at 80, knowing that it's really set on 76.
Another solution is to replace the thermostat.
Charlie
Aug 14, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Th8000 does not match another thermometer inside home
Is the thermostat mounted near a lamp or other heat source?
Is the wall warm from ducts in the wall or a refrigerator on the other side?
The thermostats are usually pretty accurate. Most times I find some other influence on the thermostat causes the problem.
The Honeywell 8000 series also has a feature accessed through the installer setup menu, that will allow the temp display to be changed + or - 8 or 9 degrees.
Check the manual or Honeywell's website for a .pdf if you need it.
Hope this helps.
Matt
Jan 11, 2009 | Honeywell Electronic Programmable...
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
since you say it has a blank face it must be a digital thermostat. if the power is on to the furnace and the furnace door is on (door switch) and still does not give you a reading. You probably have a bad stat. if you are handy.... unhook the wires in the thermostat. jump the red and white wires together. the furnace should turn on. if it does the thermostat is bad. if it does not turn on its not the thermostat its the furnace
Oct 07, 2008 | Honeywell Programmable Thermostat Heater
I have a programmable thermostat. The LED reads Replace batteries. The face plate has fan switch, a system switch, two arrow keys that are separated by three little function (set, hold, and run). HELP!!...
There is a base plate that is screwed to the wall. The face of the thermostat should come off from the base. Usually the batteries can be found back there. Some times a little tug will get it off the wall. Other models have small plastic release clasps that when pushed in will allow the unit to come off.
Jun 30, 2008 | Honeywell Heating & Cooling
EEE error message
I just talked to Honeywell support - they claim that an eee error means there has been a "unique error" and that the unit will need to be replaced - cannot be fixed. They were pretty good about giving a suggestion for a new thermostat and wiring directions if you want to DIY. Otherwise, call a pro.
Oct 29, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
887 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
