Question about RCA R52WH73 Projection Television
Phillips tv , double vision,
Model # 55pp935217 has double vision and red and green colors and I tried adjusting settings and contacted everyone in my area but they dont work on phillips or dont do big screens . Please help
    Scholar:
  • 142 Answers
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
Posted on Oct 03, 2008
Phillips 51pp9303h/17 red and green double vision of writen words and bowed line of red green at bottom. some objects in show look real shiney. and double vision of others.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Philips 9P6031C 60" Rear Projection...
Bad color; everyone and everything is very orange
contact the store you bought it from. They will help you or refund you
Mar 07, 2010 | Philips Magnavox 9P6034C 60" Rear...
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
Digital alignment on my Hitchi 46in projection tv
If the set cannot converge it self then the convergence ICs need to be replaced. Check local professional for prices
Apr 21, 2009 | Hitachi Televison & Video
Model 43FDX01B double vision with red ark across bottom . and no user manual.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
My picture is showig green,red and blue colors that can't be fixed
you need new convergence ICs. what is the model number of your set? Let me know the model number and I will be able to help you
May 09, 2008 | Televison & Video
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
RCA R52WH73 Projection Television Logo
201 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
