Need to enter service mode on RCA P60752EB LG1
  • 10,594 Answers
Here is a procedure to enter in Service Mode of RCA TV.
Another procedure is appended below.
NOTE: It is strongly advised to Be Care Full while changing data in Service Mode.
Posted on Oct 03, 2008
Need activation code rca voyager 3
If you wish to get some details; visit the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin.
Aug 17, 2017 | RCA Televison & Video
I have partitioned my LG 500G portable hdd into 2 drives(LG1 and LG2). But now my pc can only detect the LG2 and the LG1 has become "Local Disk". And when I select the Local Disk,the pc is keeps...
Open My Computer or Computer. Right click on the LG1 drive and select Properties. Under Tools, run the error checking disk utility. If it doesn't find and fix the problem, move on to...
Open Control Panel, then Administrative Tools. Open Computer Management. Open Disk Management. Right click on the LG1 partition and delete it. Right click on the empty space and create a new partition by following the prompts. Format, and you're done.
Good luck.
Jul 07, 2011 | LG XD2 500 GB USB 2.0 Portable External -...
My RCA p60752eb does not come on its makes a crackling sound, but does nothing else
u may have a bad capacitor on power supply 2200uf 25v, just look at the power supply this cap is big u can not miss it
Aug 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
Tv picture goes off but still have sound.
Resolder all poor connections on power supply board and this should fix your problem.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA p60752eb no picture porblem
most likely its a vertical deflection issue, try soldering the vertical otput IC as that may just need to be resolderd, if that doesnt help try replacing the Vertical output.
Sep 16, 2008 | RCA P60828 TV
RCA P60752EB Power problem
Apparently, blown fuses indicate problems elsewhere in the circuit. The block is a voltage dropping resistor, has nothing to do with problem. If you think it's worth it, take to pro/tech
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca p60752eb
Disconnect the lead from the flyback to the splitter. Place the flyback lead securely in a dry glass container and try to power up the set. If it doesnt shutdown the HV Block (splitter) is bad.
Feb 11, 2008 | RCA P61960 61" Rear Projection Television
Rca projection tv has sound,no picture or OSD
The 169 is an old chasis but a good one. Many chronc problems can cause these symtons. No high voltage because of bad flyback, or HV spitter defec is the most likely, but there are chonic caps that fail in the power supply as well. This problem will most likely need the assistance of a qualified service professional.
Feb 10, 2008 | Televison & Video
Televison & Video Logo
396 people viewed this question
Top Televison & Video Experts
Electro Med Services...
