Question about JVC Televison & Video
Hi, hope you can help, I have a jVC dvd recorder combi model no DR-MV5SEK. I had a power cut yesterday, not for the first time, normally all I need to do is to reset the clock, but yesterday it started flashing ‘resetting’ after half an hour nothing had happened so I turned the power off and restarted, it then started flashing ‘please wait‘ and then ‘resetting‘ this is all that happens and none of the controls work, can you please advise
  • 7 Answers
SOURCE: DVD locked in and door is not opened
For those users who just bought their machines, I would suggest warranty service. Roxanne2 should contact Philips directly with the seiral number, and they should be able to say which store they sold it to. That unit probably has a bad internal DVD writer drive.
The following solution should only be done if your machine is out of warranty unless you get permission from the manufacturer, as it will likely void the warranty otherwise:
Unplug the unit, disconnect all cables and move it to as static-free of an area as possible. Remove the cover, which usually means removing a lot of screws. Most DVD recorders have regular drives like you see in PCs. There is usually a tiny hole in the lower-right part of the drive that you can stick a small wire into, such as an unbent paper clip. You can then manually pull the drive open to get the DVD out.
Posted on Dec 08, 2007
SOURCE: JVC DR-M10 DVD Recorder not working
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
Posted on Mar 31, 2008
  • 4 Answers
might have stuck inside...u got to open up the system onlly
Posted on Apr 01, 2008
SOURCE: cannot eject DVD or turn off machine or anything
hold your power button down for 8 seconds and the machine will power down
Posted on Feb 19, 2009
SOURCE: I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
Posted on Jul 07, 2009
Need owners manual for JVC DR MV77 DVD recorder
May 29, 2011 | JVC DR-MV7 DVD Recorder/VCR
yup you should try a disc cleaner to clean the lens of your device. it might be helpful to fix your problem. try to buy that on some eletronic store. hope that helps
Sep 16, 2008 | JVC Televison & Video
LG RZ17LZ40 remote control code
Dear xxxjohn.. the only code i found that works is ..
this one..
there should also be an auto search feature .
from what i understand your remote is from a dvd\vcr type player??
Dec 22, 2007 | Televison & Video
I bought a new JVC dvd recorder vcr combo model#dr-mv79b. I lost the manual and need another one. When can I get another one?
Mar 14, 2010 | JVC DR-MV78B DVD Recorder
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
Not able to record movies/shows from cable box onto dvd recorder
Sorry I can't answer directly but just wanted to suggest you bought a PVR or personal video recorder that uses a computer-type hard drive.
These devices are a lot less hassle when only short-term storage is needed and any content you want to keep can be recorded later onto hard copy. I still prefer vhs for that as it is possible to edit tapes or cut out bad portions if something goes wrong - not something easy to do if a cd or dvd gets damaged.
Mar 24, 2017 | JVC DR-MV7 DVD Recorder/VCR
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Feb 03, 2009 | JVC DR-MV1S DVD Recorder/VCR
Jvc dr-mv100b
this is due to the settings of your player.
you should have settings for SP ( Standard Play ) LP ( Long Play ) et,c.
the quality may differ slightly, but you need to refer to your user manual for how to adjust the recording times. also if your dvd supports DL ( dual layer disks ) this will obviously double the recording times.
Mike @ Compurepair.
Jan 28, 2009 | JVC DR-MV100B DVD Recorder/VCR
I have got the RZ17LZ40 tv from LG and just got my new Sky Plus remote Rev.8 to control the tv by using code 0206.
Sep 23, 2007 | Televison & Video
I have a JVC DR-MH50 DVD/HD recorder and it will only record on DVD-R or DVD-RW not DVD+R or +RW. so check your format of disk you are trying to record on it may be as simple as that.
Sep 04, 2006 | JVC DR-M100S
Televison & Video Logo
43 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
