Question about Smeg WD16BA Front Load Washer / Dryer
Burning smell (electrical) from my washing machine
Dear Experts,
Here's a quick background to my problem:
I believe it may have started from having an unbalanced load in the drum (a heavy bath mat, though the total load was rather light). The machine made a relatively loud, hollow 'pop', which happened I believe in the first stages of the cycle (after the machine had finished loading water, and the wash had begun). Then the machine seemed to have died: It switched off, and there was no power indication - red light was off). Assuming the fuse had failed, I unloaded the machine, removed it from its housing, changed the fuse, and switched the machine back on. It then switched on successfully, and immediately burned the fuse again and died. I then used a little pipe at the bottom front to drain the water that was sitting still in the drum, replaced the fuse again, and started the machine. It now seems to work fine, except it now makes a clicking noise (which I think comes from the motor), and a burning smell ('electrical' I think) follows shortly afterwards. Let me mention that I opened the back panel and the belt is fine.
Summary of symptoms: 1) the 'clicking' noise, 2) the burning smell, and (forgot to mention) 3) the red light (power indicator) in the front of the machine is always off now, even when I turn the machine on and it seems to be otherwise working fine...
Any assistance would GREATLY appreciated.
Many thanks in advance, and thank you for your time.
Yours faithfully,
A
  • Samalakas Oct 03, 2008
    Thank you for your prompt response, appreciated!
    May I ask for a little clarification though?
    1) I looked through the Smeg spare parts website, and 'suppressor' and 'capacitor' are separate items. Is that so, and are they both located in the same place (where the mains cable goes, as you said)?
    2) I'm not sure from what you're saying whether I should replace the suppressor and/or capacitor, or fix it some other way. Please advise...
    3) I have attached pictures of the inside and outside of the mains box, for your convenience.
    Thank you very much for being so kind, I look forward to resolving this with your help!
    Kind regards,
    A
    President:
  • 1,462 Answers
Possibly the suppressor capacitor. take lid off and trace where mains input is connected and that is the suppressor. they sometimes go pop
other possibility is the neon burnt out
Posted on Oct 03, 2008
My Beko washing machine has a smell of melted rubber and I found black bits on the drum. None of the clothes have been damaged but they do smell a bit. Is it overheating or something?
hi Alyson.
this is what i found on the internet.
WHAT'S CAUSING A BURNING SMELL IN YOUR WASHING MACHINE? If you notice a burning smell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The Burning Belt Smell Many top loaders are direct drive. This means they do not use a belt. The motor is directly connected to the transmission.
In Whirlpool and Kenmore models there is a rubber coupler between the motor and transmission that takes much abuse. It's very common for the fingers or the rubber itself on the coupler to break. A clicking noise with no spin or agitation along with a slight rubber smell are symptoms of this problem.?DIY repair is possible. Older models may also have belts that can be tighted or replaced
The new Whirlpool or Maytag washer can often be fixed without calling for repair.
To work on a top load HE washer pull the empty unit away from the wall. Drape a small rug or towel over the control to minimize damage to the wall and the panel. Lean the unit against the wall and the bottom will be clearly visible. Lie on the floor and note if there are rubber pieces or shavings under the washer. The belt may be rubbing against a plastic guard attached to the motor. The solution is actually quite simple: If the belt is shredded or worn you need to replace it. You can call a repair person or, if your washer is under warranty, the manufacturer. Or, if you or someone you know is handy, you can do it yourself!
Electrical Problems If your washer smells. The first thing to do if you notice an electrical smell in your washing machine and not a rubber burning smell, is to unplug the machine and call the manufacturer or a repair person.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
or go to this link might help you to find out more.
washing machine has smell of melted rubber and found black bits on the...
Nov 29, 2017 | Beko Washing Machines
I have a f&p washing machine gwl15. It will not
That's a pump blocked error. Your drain pump is burning up and will need to be replaced.
Oct 15, 2014 | Washing Machines
Dc25 burning smell from motor
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC25. If the machine is making a burning smell, please don't continue to use it. I'd strongly encourage you to get in touch with us directly - our experts will be happy to confirm if we're able to help under the terms of the 5-year guarantee which covers all of our upright and cylinder vacuums.
You can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have your machine to hand when you call so our experts can take you through a few quick troubleshooting checks.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 23, 2013 | Dyson DC25 All Floors Bagless Upright...
Rattling sound and burning smell
im not a dishwasher repair man but i know about mechanical and electrical equipment. sounds to me like a motor has burnt or burning out probably with one of the pumps. if its during wash then its the wash pump if during drain then the drain pump (im assuming these are two separate pumps)
Dec 20, 2012 | Hoover HED661280 Dishwasher
My washer keep shorting out why is this
It may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
If the washing machine is old (15 - 20 years) you could have nuisance tripping on aGFCI outlet, however that doesn't mean you get rid of the protection of the outlet, it means you probably should consider replacing the washing machine for a newer model.
Apr 30, 2011 | Washing Machines
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
Other Causes
Nov 07, 2010 | EuroTech Washing Machines
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Burning smell when I turn on machine to start washing
Your heater is coming on with no water in machine hence smell sounds like pressure swith is jammed on depending on make could be blockage in pipe making switch think water in machine swith on heater...Remember electricity can Kill...proceed wit h caution....Find hose and give it a clean check also chamber
Sep 28, 2009 | Washing Machines
Model# LW6163WM/LM washing machine
Dear usaguitarman Welcome to fixya.com
I'm Huuum and happy to assist you,
You said, washer fills with water. then the motor overload protector starts clicking
in and out.and there is a burning smell. I am able to spin the water back out.
The belt needs to be replaced but I don't know if that could cause my problem.
Yes I believe the belt could be the problem!
That is more than likely the burning smell!
Change to belt.!
While your at it, unplug the machine for 5 minutes or more and then it will reset the system too!
Let me know how wonderful it performs after these repairs!!!!!!!!!!!!!
i believe you will be fine!
Bless You,
Huuum
Please do not forget to enter a rating when you are done.
Thank you
Sep 23, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Burn Smell (electrical) from my GE WPSE4200A0WW
We have the same problem, and found out the the electric motor is running very hot. Replacing the motor seam to cure the problem, but the motor is not inexpensive. $200 to $350.
Sep 04, 2007 | GE WBSR3140DW Top Load Washer
Smeg WD16BA Front Load Washer / Dryer Logo
1,151 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
myrlanthian
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
