Re: PIXMAMP600 I am having trouble in some instances where I get a message on the computer that my printer is off-line. I am able to print other things without a problem. When I try to print a Quicken report it tells me that my printer is off-line. What is the problem?
  • Hanixt Oct 03, 2008
    It didn;'t work by following your exact instructions. There was no Quicken icon in the printer prt of the control panel. There is no options in the Quicken file. However I found the problem in the printer set up in the Quicken file.
    Thanks for your help,
    Harry Anixter
    President:
  • 2,712 Answers
You will have to setup the default printer through the Quicken software. Click on file > printer setup > reports and graphs > (Choose your default printer from the menu) > OK.
You should be able to print from Quicken now. Please post back and let me know how it goes..
Cheers!
IrishDruid
Posted on Oct 03, 2008
    Sergeant:
  • 264 Answers
Go to Printers and Faxes under the control Panel.
Make sure that your printer is set as a default printer. If not than make a right click on the printer and select "Set as Default Printer"
Delete any other Extra printers showing up there.
All the Best
    Novelist:
  • 188 Answers
Good Morning Hanixt,
Quicken allows you to set up different printers and parameters for both reports/graphs and printing checks. This setup is a quicken function and does not necessarily use your "Default" printer.
1) Open quicken.
2) On the top left corner of the screen, choose the menu item "file".
3) From the dropdown menu, choose "printer setup".
4) Then choose "For reports and graphs".
5) Finally, use the dropdown menu to select your default printer, and choose "ok".
  • 1,879 Answers
Go to your printers and faxes and check if you have multiple printer entries, if there are, Quicken is pointing to a copy. delete those copies.
    Master:
  • 397 Answers
I am not too familiar with Quicken as I use QuickBooks, but if I am right Quicken uses a printer service like Microsoft Word and QuickBooks does.
Look in the Printer Folder in Control Panel and look to see if a Quicken printer icon is displayed, if there is one, right click the icon and check the properties to make sure your printer and not Quicken is the default printer. I have actually deleted the Word, Quickbooks and Acrobat Reader printers in the past with no problems.
You could also check the Options in File. Open Quicken and in the top left corner click File, check to see if there is an Options tab or any thing regarding the printer to make sure your printer is the default printer and not Quicken.
Lexmark x544 108.02 printhead error
1. Power off the printer/MFP, wait 30 seconds, and then power it on again. Did the error message return?
Yes: Continue to Step 2.No: Print a test page. If the page prints, the printer is working correctly.
If possible, connect the printer/MFP's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.Did the error message return?
Yes: Contact Lexmark @ 1-800-(539-6275) No: Print a test page. If the page prints, the printer is functioning correctly.
Aug 16, 2011 | Lexmark X544n All-In-One Laser Printer
My HP Colour LaserJet CM1312 has refused to print a one page document which has a few boxes on it with coloured pictures and writing. This has never been a problem on any other printer. It printed out an...
If you edit the photos and save them at a lower resolution, then put the lower resolution photos into the document, that's the quick fix.
A program such as photoshop or corel photopaint are able to do this quite easily. In corel for instance you simply resave the photo as a jpeg, and it'll ask the resolution/quality etc. and you can reduce the resolution usually quite a bit before you lose any quality in the printout.
The other solution is to upgrade the printer's memory.
Inkjet printers usually will not have this issue because they don't need to form the complete page in memory before printing like a laser printer does. An injet's image is formed line by line in the print driver and then streamed to the printer, so the printer's ram doesn't have to take the whole page at once.
Mar 25, 2011 | HP LaserJet CM1312 All-In-One Printer
C3100 Printing Fails from XP
Disable firewall to test if it is actually blocking. Windows Firewall should not normally be configured to block printing.
Make a new printer instance, but use a standard TCP/IP port
If that fails, install the driver using the canon setup.exe installer for you unit.
Mar 25, 2009 | Canon iRC3100 Printer
HP psc 1500 all in one series copier won't print just prints line
hi i/am not computer smart i'am trying to connect printer to computer that;s my trouble?
Mar 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
924 message "printer is busy"
Take out the cartridges
disconnect printer from computer
Turn off the printer
On the computer cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot.
Reconnect printer (swap cables if not detected)
Insert the cartriges
Try printing again
Have a great day!
Let me know how it is going
Pablo :-)
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Print starting over
it sounds like you have a bad main board or a bad carriage motor.
Nov 26, 2007 | OTC TriMatrix OTC560 Printer
Error code ##343
We have just attempted to install an Cannon imageclass mp360 and the error message "check printer ##343" is displayed.
Can you please help.
May 14, 2007 | Canon SmartBase MP360 All-In-One InkJet...
"Off-line" error message
Go to control panel - printers. Right click your printer icon - select delete printer. Reinstall the software and drivers via CD supplied. May have to restart your computer when complete. Go back to control panel - select printers - select add a printer and follow the instructions. When finished print a test page.
Sep 13, 2006 | Lexmark X83 All-In-One InkJet Printer
121 people viewed this question
k24674
jasbo
jasbo
