Question about Video Game Consoles & Games
The button where you turn it on is flashing one red light my freined told me it just needs updating is that true ????
  • swfc Oct 03, 2008
    no i havent got a ps3 ive got an xbox
  • 50 Answers
No this isn't true for sure  coz if it's in need of an update ... the ps3 will start n then give u a screen tellig u  there's a new update available if u wanna download it or not
Posted on Oct 03, 2008
  • mahmoud  bayoumi
    mahmoud bayoumi Oct 03, 2008
    u can check the problem simply with the sony support center in ur country
[FREIN A MAIN PORTES ] code on the odometer meens.
I looked it up on google translater and Frein A Main Portes is in French
In English it means A Hand brake Doors
Feb 05, 2012 | 2007 Isuzu i-290 Extended Cab
When turing on tv it stays frozen on philips logo. called and was told that I needed software update is this true. tv can only be tunred off by unplugging it remote or side power button will not work.
Yes, this is true. It is in need of a firmware update. Here's is where you can get the firmware update and the instructions on how to flash. Probably have to direct connect you pc via usb on the back, however I am not 100% sure. Hope this helps and don't forget to rate this high. http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL3704D/F7&scy=us&slg=en
Feb 16, 2011 | Philips 42PFL3704D LCD TV
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
I have the Hitachi Model # 43FDX11B Date Oct. 2001, I can not get the TV to turn on when I turn then power on. The only thing it does is flash a red light down by the power button. What do I need to do to...
hello, the red light is flashing because theres a fault with the tv count how many times the light flashes the this gives you an error code then do a search on google or get back to me i'll try and tell you the fault and possible fix
regards
shaun
Nov 24, 2010 | Hitachi 43FWX20B 43" Rear Projection...
My xbox told me error e79 and now it wont come on at all it just flashes red???tried removing the hard drive but it still flashes red and refuses to come on...help
Clear Any Failed system updates that cause the console to error.
1. With the console off, press and hold the sync up button (the small white one)
2. While holding the sync button press the power button to turn on the console
3. Continue to hold the sync button until the Console has booted up completely.
4. During the boot process the console should clear any failed updates, allowing you to use it normally.
Nov 18, 2010 | Microsoft Xbox 360 Console
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
One flashing red light on player 3 and 4 alternate flashing E79
E79 is a hard drive problem. It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Dec 27, 2008 | Microsoft Xbox 360 Console
42" Panasonic plasma has no picture, but power light is flashing
I think accroding to your model number this unit is plasma.
I need to know red light how many times flashing and correct model number
Sep 18, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Zebra TLP 2844 Error Condition
Qusetion, Using USB my TLP2844 detects as a LP2844ps. Weird, huh? Also when I calibrate it the label does not stop at the perferation. When I print half goes on one label and the other half goes on the next label. Someone told me once there was a trick to get it to calibrate correctly. Anyone here know this? When I print a test page, it feed the correct amount of label.
Dec 04, 2007 | Zebra LP 2844 Thermal Printer
My phone will not show it charging and will not turn on, red light flashing
Mine started acting wierd and it was flashing on and off. someone told me to press:*and # together with the power button.
Oct 19, 2007 | Cell Phones
Video Game Consoles & Games Logo
29 people viewed this question
Top Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
