Flat Panel Televisions
Problem for Panasonic Flat Panel Televisions
Generic problem for all Panasonic Flat Panel Tel...
Connecting Sony PS2 to Panasonic HT32LZD85
By Ben13 on Oct 03, 2008
The connection lead that worked with my previous tv (a traditional 26" Phillips) connected the PS2 to the aerial socket of the tv. The socket that plugs into the tv has an adapter that allows the aerial and the PS2 to plug into the tv's aerial socket.
I have tried the above set up with my new Panasonic HT32LZD85 and I get the message on the screen 'No Signal detected'
Please could you advise me what to do to make the PS2 work.
Thanks
Comments:
Oct 06, 2008
- Hi Normandez,
Thanks for your advice. I'll keep the PS2 chugging on for a little while longer!
I do remember a second cable that came with the PS2. This cable would have plugged into the back of the PS2 and it did have a 3 way ending with red, yellow and white plugs. Problem is I chucked this cable away as I thought I would never need it!
Any ideas where I might get another?
Cheers
Ben13
Best Solution
posted on Oct 03, 2008
Very Helpful)
normendez
Rank: Guide
Rating: 92%, 8 votes
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Comments:
Oct 07, 2008
- I found one on ebay but if you don't have a ebay and a paypal account you will have to set one up or scour the internet for one here is the link
http://cgi.ebay.com/Sony-Playstation-2-PS3-A%2FV-Cable-PS1-PS2-PSONE-AV-*NEW*_W0QQitemZ250303808466QQcmdZViewItemQQimsxZ20081004?IMSfp=TL081004103006r24906
Personally I would use amazon.com because you don't have to set up a entire separate account just to pay for your item and I don't trust paypal here is the link if it does not work just go to amazon and type playstation 2 in the search bar then sroll through the items till you find it. Cheers!
http://www.amazon.com/gp/offer-listing/B000GACEHQ/ref=sr_1_olp_12?ie=UTF8&s=videogames&qid=1223356916&sr=1-12
Was this helpful?
Yes
No
Solution #2
posted on Dec 30, 2008
Not Rated)
dano44gray
Rank: Apprentice
Rating: 0%, 0 votes
OK, got my Panasonic 42" 720p plasma from Bestbuy a few days ago and wanted to hook up the kids Ps2. I also had an older surround sound system, u know the all in a box one. OK back to the story: since the DVD player had no hdmi hookup, ( the connection that gives you all the HD/ vry good looking channels that u use in conjuction with a hdmi cable box from comcast, or whichever), I had to run my yellow monitor cable from my dvd palyer in the video 1, yellow slot on the back of the tv, thereby eliminating my use of the vid 1 slot for the ps2 a/v (yellow, wht and red) cables. I was able to use the frt. video 2 hookup but didn't want this to be my permanent hookup.
Solution: found ps2 "component" cable w/ ps2 connector at gamestop for about $15.00 and a 12ft. at bestbuy, on sale for $29.00. Look for these cables in the playstation section. Hook the five color coded cables into the rear component 1 or 2 slot of the tv with the other going into the ps2, select component 1 or 2 on the tv/video selector and it's game time.
note: they sale these cables for ps2 and ps3. I don't know why panasonic didn't opt for more video slots in the back of this tv, but I've found this to be a fix for palystation hook ups.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
how can i make homemade satellite disk for better viewing for my tv?
Answer
Is a 50 plasma sanyo 780p worth the money? 599.00
Answer
Black Bar with Colorful lines through the middle
Answer
I have a samsung plasma PPM42H3 42" display and I need the base for it
Answer
left side of screen is dark on our sanyo dp46868. What needs to be done?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic Flat Panel...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
Panasonic
(316) 283-8873
Panasonic
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
