Question about LG Dryers
Took the lint screen out and forgot to put it back in and a kneehigh went in the vent and made a noise. Is there any way to get it out without repairman. I cannot see the nylon and the machine is stacked ontop of my washer. LG Tromm.
  • 1,543 Answers
This being stacked makes things a lot more of a pain. Disconnect power.
  • Remove three phillips head screw at the back side of the dryer top
  • Slide top back about an inch or so and lift off
  • Remove two phillips head screws at 5 and 7 O'clock position on dryer bulkhead just behind dryer door.
  • Remove two phillips head screws on top front edge of dryer
  • Tilt dryer front forward at top and unplug door switch at top of door and light socket at top left.
  • Lift off dryer front, holding until you can unplug the moisture sensor wire at the bottom, then set aside.
  • Remove the four phillips head screws at the sides of the dryer holding the front drum support assembly.
  • Lift up assembly and pull toward you to remove.
  • You now have access to the blower.
  • Front of blower can be removed. (1/4 hex screws)
Posted on Oct 03, 2008
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 | Dryers
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
The dryer is very hot to the touch after only a few minutes in the normal cycle.
inside dryer should be two screws in lint screen holder take out screws the hole piece comes out then you can get farther into the dryer to check for lint is the outside vent clear you could pull dryer vent off run without vent on back to tell if its a venting prom or in the dryer good luck
Apr 05, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Making a terrible noise
its cloged or the pad behind it is burned up
Jan 25, 2012 | LG DLEX7177 Dryer
Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Forgot the lint screen
they are in the blower wheel duct,take the bottom panel off and take the duct off and you'll find you socks,you should also take that off once and a while and clean the lint out of it
Nov 12, 2009 | Dryers
Lint screen caked up
Take the vent hose lose at the back of your drier, and clean your lint screen off or replace it, then try drying some clothes. If this technique minimize or eliminate the caking of your lint screen, then the problem is in your vent hose. Clearly, there is an obstruction, or an improper installation of your vent hose.
good luck
Jan 15, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
128 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
