Question about Bose Wave Radio
Bose Wave Radio AWR1 1W
Older Bose Wave Radio- Does not have CD
Radio powers up...display lights up. Everything looks normal. When you turn on the radio or aux (ipod) you don't hear anything right away, but after a few seconds you hear a loud screeching noise coming through the speakers. Buttons become useless.
Must pull plug to stop noise.
Plug in radio...start again...same result.
Any Ideas?
  • hansenjustin Dec 03, 2008
    when powered on loud rumbling noise that is constant. You can't turn the sound dn or up and it constant. Only way to make noise go away is to power off...
  • artist1 Jan 05, 2009
    Same exact thing.  Model AWRC1G; Wave radio/cd.  Ready to chuck it out. Any thoughts??
  • 22 Answers
I can tell you what to check if you know how to use an ohmmeter. But I warn you you could get shocked if you do not know what you are doing. The transformer has 3 windings, two are for DC voltages, and the other is 3V AC.Your meter can measure those using the AC scale. Next, check the voltage on the 3 terminal regulator IC. One leg will have 18V, the output will have 10V. Again please use CAUTION! Finally, the to-92 transistor Q1 is used as a 5V regulator. Check it (with power off and unplugged) for any shorts, especially base-emitter. If non of these ideas work, I would offer to buy your non working unit if you decide to get rid of it.
Posted on Jun 30, 2009
    Problem Solver:
  • 16 Answers
Seems to be a common problem with these radios. check my post at what to look at . the mosfet guy.
Posted on Feb 02, 2009
A CD is stuck in my bose system How do I get it out?
From an other web site
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Oct 09, 2014 | Bose & Wave& Music System
Why does my bose wave radio turns itself off every twenty minutes?
I am not sure how to fix your radio; but my wave radio wasn't working and I took it into a Bose store and got an excellent trade in for a new one. I traded a wave radio without a CD player for a new Wave radio with a CD player. I would take your radio into the nearest Bose store.
Jul 08, 2014 | Bose Wave Radio
Bose Wave Radio/CD bad static and occasional "pop"
Hi, When you change the Aux turn the radio off. Then turn it back on. As for the static move the radio to another plug or to a different room. If you have floresecent lighting it may do that too.
The cord acts like an antenna so don't bundle the cord. Good luck.
Sep 22, 2011 | Bose Wave Radio
I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Mar 21, 2010 | Bose & Wave& Music System
How can I get the Bose Wave radio to work in Europe??
Yes. The tuner spacing option should do this. If it's a Wave Music System or a Wave Radio II, go into the 'setup menu' and look for 'tuner spacing'. -If it's older, you may want to call Bose for a solution.
Jun 11, 2009 | Bose Wave Radio
My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Mar 26, 2009 | Bose Wave Radio
Will not turn on
See if the problem is connected with the cord, then replace the cord.
Jan 07, 2009 | Bose Wave Radio
No power
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to give owners of broken sets a $200 allowance towards the purchase of a new Wave. Before spending the big bucks though, you might want to check out the new HD radios. Better sound and a MUCH lower price.
Nov 11, 2008 | Bose & Wave& Music System
Bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Aug 09, 2008 | Bose Wave Radio
Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Apr 09, 2008 | Bose Wave Radio
Bose Wave Radio Logo
1,003 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
