Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Regedit start,run,regedit,ok. Windows cannot read "regedit" ensure you have typed name correctly
  • owners Feb 24, 2009
    my shows regedit was disiable by your administrator pls give solutin for this
  • 29 Answers
Admin734's Solution would work but mine may be quicker.
Put your windows cd in the drive and search it for regedit.exe, it should be in the d:\I386 folder. Once found copy and paste it to your C:\windows\system32 folder.
problem should be solved.
Posted on Oct 03, 2008
When i try to run edit on DOS prompt it shows it is not an internal or external command
Posted on Feb 24, 2009
I am logged-on as a user that belongs to Administrator group on my laptop. Start, Run, regedit comes up with message "registry editing has been disabled by your administrator". same happens with regedit32.
Posted on Feb 03, 2009
    Sergeant:
  • 268 Answers
Sounds like you may have a virus , that is usually the reason your regedit would go missing.
Here is your fix:
  1. Get your Windows XP CD (Should have came with the PC)
  2. Goto "Start"
  3. Goto "Run"
  4. Type in "CMD" and hit enter
  5. A black DOS screen will come up , type the command "SFC /SCANNOW" and hit enter
What This Will Do -
This command checks all of the Windows system files on your computer against the CD to make sure that you have them all and that none of them are corrupt. If you are missing any files it will pull it off of the CD automaticlly......after the scan is done try accessing regedit again....
Also this is usually signs of a virus , so after you get that fixed I highly recommend that you do a virus scan along with a spyware scan.
I have Casio SE-S300 how to reset a bussiness name as new? Pls
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
Locate the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion
To change the company name, do the following:
In the right pane, double-click RegisteredOrganization. Under Value data, type the name that you want, and then click OK.
To change the name of the registered owner, do the following:
In the right pane, double-click RegisteredOwner. Under Value data, type the name that you want, and then click OK.
Click Exit on the File menu to quit Registry Editor.
Jan 13, 2014 | Computers & Internet
Tip
How to Enable Task Manager in Windows XP
Method 1
  • Click Start, Run and type Regedit.exe
  • Navigate to the following branch:
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  • In the right-pane, delete the value named DisableTaskMgr
  • Close Regedit.exe
Method 2: Using Group Policy Editor - for Windows XP Professional
  • Click Start, Run, type gpedit.msc and click OK.
  • Navigate to this branch:
User Configuration / Administrative Templates / System / Ctrl+Alt+Delete Options / Remove Task Manager
  • Double-click the Remove Task Manager option.
  • Set the policy to Not Configured.
on Dec 08, 2009 | Computers & Internet
I cant change the wallpaper of my acer D260 how should i remedy this one?
You might have Windows 7 Starter, please be advised that Windows 7 Starter does not include Personalization feature for changing desktop background, window colors, or sound schemes.
However, there is a solution for the desktop wall paper for Windows 7 Starter. You have to deal with the Registry. Please read my notes below.
  • · Click start
  • · In the search box or run, type regedit, allow execution
  • · (Important, export the current registry setting) Right click on Computer and export the registry setting.
  • · Navigate to "HKEY_CURRENT_USER\Control Panel\Desktop\"
  • · On the right hand side pane, doubleclick on key named "Wallpaper"
  • · Change the path of the picture you want to use as your wallpaper (example path is "C:\temp\mywallpaper.jpg")
  • · Right-click on the "Desktop" folder in left pane click Permissions. Click "Advanced"
  • · Go to "Owner" tab, highlight your name in the box that says 'Change owner to' ( There are only two choices the other is Administrator )... once your user name is highlighted click "OK"
  • · Click on "Advanced" again then Uncheck the button that reads "Include inheritable permissions from the object's parent"... click "Remove" when prompted
  • · Click "Add". Type "Everyone" and click "OK". Check Allow "Read Control" and click "OK". Click "OK" again
  • · Highlight "Everyone" and check to Allow "Read" and click "OK"
  • · Restart Computer
Jul 15, 2011 | Acer Aspire One PC Notebook
I m unable 2 change my theme and wallpaper
If your operating system is Windows 7 Starter edition, the customization is disabled. Consider upgrading to Windows 7 Home Premium or other edition for these features.
BTW . I found a hack for the wallpaper change in Windows 7 starter edition. if you want to try,
1. Click start and type regedit in the search box or run
2. Go to "HKEY_CURRENT_USER\Control Panel\Desktop\" folder and click on it
3. On the right hand side you will find a bunch of entries. Find the key named "Wallpaper" and double click on it and put the path of the picture you want as your new wallpaper (example path is "C:\Users\Big Dan\Pictures\new wallpaper.jpg")
4. Right-click on the "Desktop" folder in left pane click Permissions.
5. Click "Advanced"
6. Go to "Owner" tab, highlight your name in the box that says 'Change owner to' ( There are only two choices the other is Administrator )... once your user name is highlighted click "OK"
7. Click on "Advanced" again
8. Uncheck the button that reads "Include inheritable permissions from the object's parent"... click "Remove" when prompted
9. Click "Add"
10. Type "Everyone" and click "OK"
11. Check Allow "Read Control" and click "OK"
12. Click "OK" again
13. Highlight "Everyone" and check to Allow "Read" and click "OK"
14. Restart Computer
Feb 22, 2011 | Dell Inspiron Mini 10 Notebook
I cant change the company name i bought this register from someone else not the company casio
you can do this by using following the below steps:
1. Click Start, Run and type regedit, and then click OK. Navigate to the following location: HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion 2. To change the registered organization, double-click RegisteredOrganization.
3.Under Value data, type the name that you want, and then click OK.
4.To change the name of the registered owner, double-click RegisteredOwner.
5.Under Value data, type the name that you want, and then click OK.
6.Click Exit on the File menu to quit regedit.
or u can use this link to download a tool to do the job automatically
http://windowsxp.mvps.org/utils/ChangeOwner.exe
Jan 23, 2010 | Casio Parts Cash Register PC Desktop
Task manager has been disabled by spyware plz tel me how can i solve this problem i have windows xp.
try google... there is a fix by a downloadable free software. usually caused by a virus.
Jan 14, 2010 | Toshiba Satellite A135-S2276 Notebook
I need k9 off my computer NOW!
Can you try this please : Go to start;
  • then run
  • type in regedit
  • go to edit
  • then find, in the box type in the name of the program then hit enter key
  • it will search every instance of that name in the registry
  • make sure the entry relates to that program then hit delete key
  • then ok to confirm delete
  • then F3 to continue search
  • continue deleting,ok,F3 ,untill you reach the end of the registry
it is very important that you make sure you are deleting the correct entries as you can do a lot of damage if you delete something that windows needs ,to be able to boot
Hope this helps
Jul 04, 2009 | Dell Inspiron 1100 Notebook
Taskmanager disabled by your administrator
Click on start then run
Type gpedit.msc then ok
Click + on administrative templates
Click + on system
Click on CTRL ALT DEL options
over to the right double click on remove task manager
Click on disabled then apply then ok
You will now have back taskmanager
This is normaly caused by malware you should if you havent already run an anti malware scan.
Malware Bytes is an excelent example of a scanner and is located here: www.malwarebytes.org get the free trial version its great.
May 07, 2009 | Microsoft Windows XP Professional With...
My taskmanager has been disabled by virus
Method 1 Click Start, Run and type this command exactly as given below: (better - Copy and paste)
Method 2 Download and run this REG fix and double-click it.
Method 3
  • Close Regedit.exe
Method 4: Using Group Policy Editor - for Windows XP Professional
Feb 12, 2009 | Computers & Internet
About folder option
Click on Start - Run and then type:
Regedit
then go to
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Explorer\Advanced\Folder\Hidden\NOHIDDE N.
There should be two registry entries there:
- CheckedValue : Type: DWORD Value: 2
- DefaultValue : Type: DWORD Value: 2
(Correct them if necessary.)
Now open the key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Explorer\Advanced\Folder\Hidden\SHOWALL .
- CheckedValue : Type: DWORD Value: 1
If the problem persists, open Start, Run, type "regsvr32 /i shell32.dll" and
click OK.
reboot the computer.
thats it, have fun :)
Jan 06, 2009 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
156 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
