Question about GE ZICS360NMRH Monogram® 36" Built-In Bottom-Freezer Refrigerator (ZICS-360NMRH, ZICS 360NMRH)
GE zir36n rh Monogram 36" built in refrigerator
There is a constant problem with excess moisture in the unit, build up of mold on condiment containers and all surfaces of the interior, as well as rusting of metal parts. recently dismantled the entire interior, steam cleaning all surfaces as soon as it was up and running water started accumulating in the bottom of the case!  Now what do I do?
  • 1 more comment
  • c1keil Oct 03, 2008
    thanks for the suggestion, but since this unit is built-in pulling out the fridge is not so simple. Can a not so handy homeowner accomplish this? or do I need to call in a repairman?
  • Anonymous Oct 11, 2008
    i have never had mold in a refrigerator --- and i have to clean this one thoroughly every few months because of it - it is a huge refrigerator - don't see how i can pull it out from it's built in space
  • sully02 Dec 23, 2008
    I have mold all the time in my frig (cost $4,000 for the frig so I was not expecting this problem.) This is for a GE Monogram 36" refirigerator. The freezer is a separate unit that is 36" Does any one have a solution?
I finally got my refrigerator fixed after three years of complaining. The units are set up to have the fan running even if the cooling unit is not currently on. So when the unit is not cooling, then the fan is brining in moisture from the outside air which causes the water/mold. GE repair rewired the fan to run only when the unit cools on 4/20/10 and it has fixed my problem!!! Of course, this was only after I have thrown out a LOT of food!
Posted on Jun 08, 2010
  • nike00 Feb 21, 2011
    Hi Phall525, can u advise if your fridge is still working fine without the mold issue after the fan was rewired? I am having the exact same issue and it is killing me. A tech replaced thermostat once and it is still molding. where are u located and do u have the repairman contact? i called ge back a few times but they have no clue! pls help!
  • 943 Answers
Hi the problem you are having, is that the drain tube going to the drain pan, at the bottom of fridge is clogged up . pull fridge away from the wall. remove back panel ,clean all coils. find the drain tube and clean . thanks the appliance doc
Posted on Oct 03, 2008
  • john gagnon
    john gagnon Oct 03, 2008
    Hi. well if you can get at the drain tube . get a small plastic hose, from the hard ware store .and push the small hose down the drain tube. and blow through the tube. this should clear the blockage . thanks. the appliance doc
Black mold growing inside of the fridge
Scrub scrub scrub with a mild bleach solution, and then keep a couple of open boxed of Baking Soda inside, changing them frequently.
Inspect your door seals, I bet you will find a rip, tear or some other leak which is allowing warm, moist air into the fridge and encouraging the mold growth.
Also consider setting the temperature much colder to inhibit the mold growth.
Although there are many mold-killing solutions on the shelf at the hardware store, a good old fashioned mild Bleach solution is your best bet, as it is acceptable for use around food.
Jan 25, 2014 | GE Monogram ZIR36NMRH Refrigerator
Any solutions for constant black mold growing in GE Monogram refrigerator? It is not a lack of cleaning problem. Never had a refrigerator do this before.
Permanently removing mold from a refrigerator is tricky because mold likes cold dark places (like refridgerators). However, I would try a stonger cleaning solution such as bleach. The attached link explains how to get rid of mold:
http://www.ehow.com/how_6557971_remove-mold-fridge.html
Feb 26, 2011 | GE Refrigerators
36" SxS not cooling
unplug it for five minutes... if it dosent come back on the pc board must be replace....
Apr 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
My GE monogram built in refrigerator is not staying cold
GE Mono frig are built with shut off senser on the compressor. Wipe the condenser coil with damp cloth. This will resolve the problem. This lession cost me $160.00 from GE frig tech guy. Not to mentioned using my clean cloth and wiped for just 5 minutes.
Nov 07, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Water is pooling in the bottom of the refrigerator. this model does NOT have an automatic ice maker, nor is connected to any water source. model #frt18g4awo
This is usually caused by the drain tube being plugged. There is usually a collector tray mounted under the refrigerator near the compressor and a small drain tube that runs into the refrigerator. The tube will plug with slime and green mold over time. Without knowing the model or make I cannot tell you for sure where the tray is located. If you find the tray you should see a tube laying into or hanging above the tray and running up to the refrigerator. Clean this tube and the little drain hole in the refrigerator with a pipe cleaner or soft piece of wire. Also check your door seals as a bad seal will also cause excess moisture to form in refrigerator, and children constantly opening and closing will also cause excess moisture to form and if the drain is plugged it will build up in the bottom.
Oct 07, 2009 | Refrigerators
GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Aug 25, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Door on Monogram ZIR36N won't pull closed and stay shut
The spring is actually a door closure , are the wheels that the bar closure mechanism goes through and attaches to the spring moving freely? It is entirely possible that a bin in the fridge is keeping the door open.
Nov 14, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
Refridge
Sounds like the icemaker mold is leaking so the whole icemaker should be replaced.  Leaking water will get on the icemaker heater and cause condensation which then freezes and makes frost.
Oct 17, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
868 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
