Question about Panasonic PT-47WX42 47" Rear Projection Television
Tv problem did you get your problem resolved? I have the same issue
    Sergeant:
  • 284 Answers
Yes it did fix my problem but you need a tech to look at it. if your in canada i can recomend a dealer
http://www.panasonic.com/support/?cm_re=1-_-Top%20Mast-_-Support here is where you can get a dealer close to you.
Posted on Oct 07, 2008
The Timer/Standby LED light is flashing on the front of the TV. Can turn on TV with sound but no picture, TV shuts off within 5 seconds.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Aug 08, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
KDF 50E2000 WONT POWER UP POWER LITE BLINKS RED 3 TIMES THANKS
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
May 12, 2011 | Sony KDF-50E2000 50" HDTV
TV turns itself off and power light flashes green
May 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Green light keeps blinking will not turn on at all
May 11, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
When i try to turn it on i get picture and sound for about 2 seconds and then it shuts off and the red light flashes,
May 07, 2011 | Sony KDS-R50XBR1 50" HDTV
Standby light keeps blinking but no picture
May 01, 2011 | Sony KP-53S65 53" Rear Projection...
The stand by light keeps blinking, this has happened before but then the TV came on. What to do as it has been blinking for a long time now.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps,service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Nov 15, 2010 | Sony Televison & Video
TV turned off while watching and will not power up again. The red light appears and then shuts off, no picture at all.
Jun 30, 2010 | Sony KP-53HS30 53" Rear Projection...
Tv keeps turning itself off and then back on. green power light blinks. If i tun it off when it does that the red power light blinks 5x repeatedly.
Jun 22, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
KP57WV600 SCREEN TURNS GREEN THEN BLANK
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
