Question about E-Machines eMachines Desktop PC
E-machine W6409 When my son turns the monitor on, it says "frequency out of range". We've tried resetting. We've upluged and pluged back in after 2 minutes and still the same thing. My son is autistic and uses his computer mostly for music and watching movies. Please help!
  • 4 more comments
  • spikette51 Oct 03, 2008
    When I shut down and turn back on, monitor says e-machine. Then VGA comes up. Then the windows startup flashes and goes blank except for the Frequency Out Of Range. To answer your question. bluegreenash...your solution looks very helpful but I am a dork with big D, and have no idea how to do a safe mode start, but i'll look it up and try it. Thanks so much!!!!!
    Thank You. Got it into safe mode and goes blank at windows startup and "frequency Out Of Range" comes up again. re-boot and even tried last known good configuration (your most recent settings that worked) and that didn't work. got to the windows startup for like 8 sec, the screen went black and the frequency thing. maybe the VGA card is bad? *scratching eyeballs out* Then there is the 9500+ songs he has in there.aaarrrggggg! Well I tried.
  • spikette51 Oct 04, 2008
    I'll do the switch thing on my computer. If it's the computer, i'll just get another one from Newegg. Thanks so much for all your help.
  • Taylor Ray Feb 21, 2009
    ill be using my e machine and then out of the blue the screen goes blkank then say frequency out of range and i have to resart the computer to fix it
  • martinezm713 Feb 21, 2010
    Well guys I have an E machine W6409 ans i have been having a problem with it it seems when i turn on the computer it gives the emachine logo the it gives me the RGB No Signal then the screen turns off as for the PC you can hear the fan just going it never shuts down NEED Help i check the monitor with my laptop and i know it works so any suggestions would gladly help
  • Cason Ramos May 11, 2010
    If you shut down and turn the PC back on, does the monitor display anything as the computer is booting up?
    Problem Solver:
  • 7 Answers
When your system beging to boot up, start pressing the F8 button when you see the white text on the screen. You should see a menu with an option to boot into Safe Mode. Then follow the instructions provided by bluegreenash.
Posted on Oct 03, 2008
  • 661 Answers
The PC has been set to use an invalid display resolution,
to rectify this boot PC into safe mode, right click on the desktop (not on an icon) select properties
select the tab for settings, and choose the display resolution 640x480,
then reboot pc into normal mode, then using the same process above , select a more appropriate resolution for your display (remembering to also turn up the colour setting to at least 32 bit)
  • Gareth Cockram
    Gareth Cockram Oct 03, 2008
    hmmm, it should work in safe mode.........unfortunately without another monitor (or PC) to test it is impossible to verify if it is the monitor or the pc at fault.... that is the next thing to check
    either Test PC by connecting a different monitor
    or
    Test Monitor by connecting it to another PC
    from these tests you should be able to discover which is faulty.
  • Gareth Cockram
    Gareth Cockram Oct 04, 2008
    you won't need to replace the whole computer if it is the PC at fault, just the graphics card
    you will most likely need this info to replace your graphics card (see section on compatibility)
    http://en.wikipedia.org/wiki/AGP
Nf code, new cold water valve, cleaned screens, drain good, uplugged and pluged back in still no cold water
trying turning the water off. disconnecting the hose at the valve and hooking it up again.
Feb 02, 2015 | Washing Machines
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
Keep getting "frequency out of range" meassage
Sounds like there is an issue with the video card settings versus your monitor.
Try the following:
1.) Press F8 on boot and select VGA mode then once into the OS reset the video card options
2.) Try another monitor
3.) If you have video card, swap it out. If you have onboard graphics put a card in
Cheers...please post your results.
Nov 05, 2010 | Gateway D710 PC Desktop
Monitor displays frequency out of range.....need help . How can I solve this?
The frequency is out of range because the VGA graphics card is not compatible or set right for the monitor's set of frequencies that it can work with.
Try another VGA graphics card.
Or upgrade the card to one with DVI, and upgrade the monitor to one of those 24" DVI Samsung monitors. They're nice. I got one from Best Buy a few years ago, and never regretted the larger desktop.
Good luck on this one.
Jul 10, 2010 | E-Machines eMachines Monitor E15T4
Frequency out of range
the monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
My monitor says "out of range" H. frequency: 96.4 Khz V. frequency: 119.6 hz
You have to configure your monitor turn it down the frequency of your monitor range
Jan 07, 2010 | Office Equipment & Supplies
"out of frequency range" message nothing works
Try booting to the ENABLE VGA mode off the F8 menu if you can get to the desktop and then you can go to display properties and see if you can reset the resolution to normal. If no go, try updating the video driver
Oct 02, 2009 | HP Compaq FS 7550 17 in.CRT Conventional...
When computer is booting up, the monitor goes out before it gets all the way up and says the Horizontal, and Vertical is out of range. The menu says that the freq. is now Hor. freq. 91.1 KHZ, and Vert....
Turn the monitor on without turning computer on. Use the OSD (On Screen Display to lower the refresh frequencies. On the monitor look for a Setup button. The arrows allow you to scroll through the options. Do not forget to save settings.
Hope it helps.
Sep 20, 2009 | Computers & Internet
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
E-Machines eMachines Desktop PC Logo
371 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
