Toshiba satellite touchpad & keyboard stopped working
My laptop touchpad & keyboard stopped working so i wiped it and put xp back on and it still doesn't work, if i go into bios and disable pointer device the keyboard works in xp, usb mouse works. but now i cant even find my touchpad in windows and i dont know what i can do to fix the problem
  • 6 more comments
  • howden19 Oct 03, 2008
    Toshiba Satellite 1410-401 the keyboard works in bios, it only works in xp if i disable internal pointer device in bios. in mouse properties there is no sign of a touchpad, the keyboard and mouse just suddenly stopped working
    yes i opened it up to replace a hinge before it stopped working but it worked for a bit after i put it back together and have checked again to see if there was any loose conections. when i took it apart there were two wires a black and a white that looked loose but when i looked at them i could not find anywhere that they could have come from and looking at them closer they had tiny little thins on the end that looked like sensors of some thought, they were not near the touchpad. yes a usb mouse works
    i have not noticed anything else wrong apart from windows cant find pci modem driver
    Hi, Thanks, before i read this i solved it, it was the touchpad that had come loose without me relising TWICE. Those wires go upto screen i think, will check out the link you left below but i wasn't aware this had a wifi card or dont think it does as i been using wifi adapter. Thanks again.
    Hi, your right about the black & white wires, I just checked, its got no wifi card but they were taped down there and when opened they came out inside and thats why i didnt know where they had come from. thanks for the links, wish i had them a few days ago, i couldn't find any. when i opened it i didn't know which way to do it so i just unscrewed everything, it took a long time to put back together though, but didnt touch the touchpad conection at all.
    Thanks
    Paul
  • Anonymous Oct 30, 2008
    asas
  • Anonymous Jan 11, 2009
    My touchpad is not working. Some of the control keys (fn keys) don`t work too. I have formated the computer, put the drivers and i still can`t use the touchpad. Help me please.
  • Anonymous Mar 22, 2014
    some of the letter on my keyboard stopped working, nothing was split on the keyboard they just randomly stopping working.
  • 3 Answers
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Posted on Oct 03, 2008
  • CheTzu
    CheTzu Oct 03, 2008
    Was your laptop opened recently by you or any one else? I recently had the same problem and it was fixed by readjusting a connector inside. So please let me know if you had opened it up recently.
    Does your usb mouse still work?
    And have you noticed anything else not working on your laptop like lights that used to be on or blink, etc?
  • CheTzu
    CheTzu Oct 03, 2008
    Ok we might be getting closer to a solution.
    If your interested on how to dismantle go here.
    http://www.irisvista.com/tech/laptops/To...
    Its not your laptop but its from the same 1410/1415 series so it wont be that different. That website is your friend right now.
    If you take a look at step 4 you will see that those two black and white cables belong to your wifi card. http://www.irisvista.com/tech/laptops/To...
    Does your wifi work?
    If you look at step 13 you will see the wires that connect to the touchpad.
    Double make sure that it is all good. I know its frustrating but it
    might be the source of the problem. Let me know how it goes and good
    luck.
Keyboard, touchpad and external mouse stopped suddenly..for Toshiba satellite l3900
Press function key on keyboard F5 to see if this helps turn on mouse / touchpad
Jun 21, 2016 | Toshiba Computers & Internet
On a Toshiba Laptop C70-A Series , lost my arrow and some keys dont work. How can I get my mouse back, so I can do a backup ?
Depending on your laptop settings start by doing a FULL shutdown. After rebooting hopefully the mouse (assume you mean a touchpad) will be restored; and maybe the keys not working. If unsuccessful connect a USB mouse and USB keyboard and check settings of the touchpad and also select the default language keyboard. If still unsuccessful try reinstalling touchpad drivers. Consider a possibility of some problem or damage to the keypad and/or touchpad if this all happened recently and the above doesn't correct.
Dec 11, 2014 | Toshiba SATELLITE PRO C70-A SERIES Laptop...
How to enable touchpad on Toshiba Satellite L850?
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Oct 27, 2012 | Toshiba Satellite L850-BT2N22 Customizable...
Toshiba Satellite 1905-S303 keyboard and touchpad mouse will not work
Hi TiKLe
Try to go into the "safe mode" by pressing repeatdly F1,or F2 or F8 (depending on your computer) and reinstall your keyboard/touchpad drivers from the Toshiba website below.
If that does not work, then try downloading the drivers on a thumb/flash drive on a different computer and go into the safe mode on your computer and insert the flash/thumb drive in and download the drivers for your computer that way.
Go to the following webpage and download your drivers.
Please rate me
Bud
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=256525&rpn=PS192U&modelFilter=1905-S303&selCategory=3&selFamily=1073768663
Sep 26, 2012 | Toshiba Satellite 1905-S303 Notebook
Touchpad stopped working when a friend openned the laptop to fix the DC power pin. reinstalled driver, power cycled, disabled and enabled touchpad, still only works with mouse. keyboard works fine
Most probably, your friend disconnected the cable connecting the touchpad to the motherboard while disassembling the laptop to fix the DC power pin, & forgot to reconnect it back.
You will need to partially disassemble the laptop again & reconnect the touchpad to the motherboard.
Nov 13, 2010 | Toshiba Satellite A60 Notebook
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
I have a Toshiba Satellite Laptop. The mouse pad is not working.
You might need a palmrest/touchpad replacement. Check the touchpad cable connection on the motherboard first. Remove it and reinsert in its place. If still not working you have to replace the assemble.
Oct 03, 2009 | Toshiba Computers & Internet
Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Apr 14, 2009 | Toshiba Satellite A60 Notebook
Help me to unlock a laptop keyboard
I had the same problem for my laptop as well. I basically turned it off and removed the battery for ten minutes, then put it back in and turned it on to which it started working. I don't know why it stopped working before or started to work again when I removed the battery but it's happened three times and everytime that has always worked for me. I know it's not very technical but try it.
Jul 02, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
5,104 people viewed this question
David Payne
David Payne
