Question about Acer Computers & Internet
Acer fp 855
The Brightness adjustment no longer works (it shows "0-1" only in manual controls). I can only use the auto setting. Is this monitor worth repairing? What is currently equivalent if I want to buy a new one? Thanks so much, Dean Pappas
    Champion:
  • 293 Answers
Hi Dean,
Open your on screen display, used the +- buttons to go up & down. In this case used the - button to find the brightness setting. When you see reached the brightness setting press the first button ( the one you used to open the on screen) to activated the changed. Now used the + to adjusted the brightness to your desired. Well, hope i can help you on these. If not just give yourself a new LCD monitor for Xmas. Now a days...it's only cost about $200 for a 20" widescreen. Have a nice day!
Posted on Oct 03, 2008
How do i turn light on or off
If you're referring to your display brightness, you can control this in your Settings. Use the Settings App and Open the Brightness &Wallpaper menu. Select the brightness level on the slider and flip to auto-brightness if you like. This will adjust brightness based on ambient lighting detected by your front-facing camera. If that's causing you problems, disable the auto-brightness and just control it manually from the slider.
Mar 29, 2014 | Apple iPhone Cell Phones
No way to adjust screen brightness
Hello, It is possible to adjust your brightness from your graphics settings. most likely there is a graphics icon located with the icon collection (show hidden icons) by your clock. Hope this helps Good Day
Feb 12, 2014 | Gateway Acer Black ZX4971G-UW20P Desktop...
ACER ASPIRE BRIGHTNESS STAYS AT EITHER 100% BRIGHTNESS OR 0% NOT INBETWEEN
You are correct in thinking it may be a driver issue. Check the device manager and see if the drivers are installed. Under "Display Adapter", you should see the make and model of your device. If it shows up as Standard VGA Adapter, then you are using built in drivers and should look for the right drivers.
If everything looks good otherwise, then you are probably looking at a faulty LCD/LED. A faulty LCD/LED can yield all kinds of problems, and replacing the entire unit is usually the easiest option. On average an LCD/LED is more or less $50.
Sep 17, 2012 | Acer Aspire 5735 Notebook
Acer Aspire 5250 Show Pic
On most Acer laptops, you can adjust the screen brightness this way:
Press and hold the blue 'fn' key. Look at the arrow keys. The left/right arrows should have a picture off the sun on them. Tap these keys while holding the fn key to adjust screen brightness. Please let me know if this does not work.
Joe
Apr 08, 2012 | Computers & Internet
Can you adjust the screen brightness to brighter? ACER ASPIRE ONE?
Hello. yes. to adjust the screen brightness, go into the control panel and find the brightness or contrast adjustment. Joe
please rate my answer as 4 thumbs up. thanks.
Oct 02, 2010 | Acer Aspire One PC Notebook
Hello, i have a Fujitsu A6120 laptop and the options for adjusting brightness (thru control panel and manual adjustment by key-function) are not working. the brightness is just set to maximum. I?d like to...
Either adjust them with your graphics cards control panel(right click desktop and screen setting should be there, or from the control panel)
or adjust it through the power options menu in control panel
Jul 10, 2010 | Fujitsu LifeBook A6120 Notebook
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
Moniter brightness
Have you tried using the manual controls on the keyboard for changing the brightness (Fn right arrow)?
I think the epower management is crap, usually I just uninstall them all and adjust things manually.
Jan 12, 2008 | Acer Aspire 5100 Notebook
Built-in flash and an external flash simultaneously
Yes, please see the following table: Optional Flash Flash Control Mode Capacity FL-50 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The FL-50 flash can be connected with the E-300 camera through flash power grip: FP-1 and flash cable: FL-CB05. FL-40 Auto/ Manual The external flash cannot be used with the built-in flash. * Only Auto and Manual mode can be set in the concurrent use of FL-40 and the built-in flash. (For their specification design, E-300 and FL-40 can not communicate in TTL Auto and R-TTL Auto modes.) FL-36 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The external flash can be used with the built-in flash.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Computers & Internet Logo
431 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
