Question about Toshiba Satellite 1410-S173 Notebook
Toshiba 1410-401 my laptop touchpad & keyboard stopped working so i wiped it and put xp back on and it still doesn't work, if i go into bios and disable pointer device the keyboard works in xp, usb mouse works. but now i cant even find my touchpad in windows and i dont know what i can do to fix the problem.
Toshiba Satellite 1905-S303 keyboard and touchpad mouse will not work
Hi TiKLe
Try to go into the "safe mode" by pressing repeatdly F1,or F2 or F8 (depending on your computer) and reinstall your keyboard/touchpad drivers from the Toshiba website below.
If that does not work, then try downloading the drivers on a thumb/flash drive on a different computer and go into the safe mode on your computer and insert the flash/thumb drive in and download the drivers for your computer that way.
Go to the following webpage and download your drivers.
Please rate me
Bud
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=256525&rpn=PS192U&modelFilter=1905-S303&selCategory=3&selFamily=1073768663
Sep 26, 2012 | Toshiba Satellite 1905-S303 Notebook
Touchpad stopped working when a friend openned the laptop to fix the DC power pin. reinstalled driver, power cycled, disabled and enabled touchpad, still only works with mouse. keyboard works fine
Most probably, your friend disconnected the cable connecting the touchpad to the motherboard while disassembling the laptop to fix the DC power pin, & forgot to reconnect it back.
You will need to partially disassemble the laptop again & reconnect the touchpad to the motherboard.
Nov 13, 2010 | Toshiba Satellite A60 Notebook
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
MOUSE PROBLEM
run a virus checker through i had the same problem with the moving mouse thought i had a good virus checker but somehow it got through hope this helps regards Jim
Apr 23, 2009 | Computers & Internet
Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Apr 14, 2009 | Toshiba Satellite A60 Notebook
Acer aspire 1302 keyboard, touchpad, usb doesn t work
check with your keyboard works in Bios
please check with external key board
if it works ,then need to change the key pad
Mar 14, 2009 | Computers & Internet
Toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Oct 03, 2008 | Computers & Internet
Acer Extesa 6601 Keypad & Touchpad Problem
you need the drivers for the touchpad and keyboard, click on the drivers and utilities section, then allow active x when the pop up appears
http://support.acer-euro.com/drivers/notebook/ex_6600.html
Aug 23, 2008 | Acer Aspire 5100-5022 Notebook
Acer Aspire 3004 keyboard and touchpad error
Just resolved same problem on Acer Aspire 5000 by removing the battery, then goto device manager and disable "Microsoft ACPI-Compliant Control Method Battery" you can then put your existing battery back into the latop with any problems with the keyboard and touchpad. Mad solution I know but it worked for me
Jan 22, 2008 | Acer Aspire 3000 Notebook
Toshiba Satellite 1410-S173 Notebook Logo
154 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
