Question about Kenmore Refrigerators
My Kenmore side by side fridge is not cooling
It has been making a buzzing sound the past couple of days like something is trying to turn on but then just clicks off. This mornign everything in freezer is completely thawed and the fridge side is not very cold either. What is going on???
  • 750 Answers
Hellocdbowling
welcome to fixya
You said,
Do not wait to call service .
Before your food is all ruined.
You may need to find the leak and replace the a shot of coolant that may have leaked out!
But be ready for anything if you let it go with that buzzing sound for a long time with out correcting it!
If it sounds wrong, it is!
Next time follow your feeling and act. Don't wait!
I am sorry I am not able to be there hands on.
Thank You for asking us for our advice.
Huuum
Please remember to leave a rating!
Posted on Oct 03, 2008
Model # (P) 55662 serial # (S) 10149733GT Freezer is at 41' and fridge is at 49' and both are climbing. they were at 38' & 48' respectively this morning. * hours ago we tried: ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore side-by-side refrigerator. It has been tripping the circuit breaker for a couple of days and now temp is droping in the fridge and freezer.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 01, 2011 | Refrigerators
Fridge sometimes amkes a buzzing sound when motor
It is quite normal for some models to make this sound while running. As long as everything else is working properly then there is nothing to worry about.To be more precise, if the unit starts and turns itself off after a short while then the thermostat etc... are working fine.
Apr 05, 2010 | Refrigerators
Amana side by side, buzzing, no fan in fridge.
that sound is the relay/overload. it is trying to start the compressor. the problem is either that relay or the compressor itself
Feb 05, 2010 | Refrigerators
Kenmore Elite Trio not cooling
sounds to me as if the compressor is overheating and shutting itself down (the buzzing noise) Once a compressor overheats it throws itself into what is called thermal overload. There are several reasons that a compressor will do this. But you said you turned it off and back on and it worked for a while. If this is so then it is possible that your unit could be low on freon or the coils under the base of the fridge has a lot of debris on them. To clean the coils just purchase a coil brush from your local hardware store and using a flashlight to see, brush all of the debris off the coils. make sure to unplug the unit before doing this. If the coils are clean then you need to have the pressures check on your compressor to see if the proper level of freon is there. An appliance tech should be able to check this for you for a minimal cost. Good Luck
Dave
Jul 17, 2009 | Maytag MSD2656G Side by Side Refrigerator
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no...
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer only cool, fridge not cold as well
it sounds like the relay on the back of the unit may have gone bad.or the compressor has a leak in the line...call a tech out and have it checked...it may be cheaper to get a new fridge
Aug 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
82 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
