Question about Ricoh Aficio SP C411DN Laser Printer
Ricoh Aficio SP C410dn
Power keeps tripping main breaker which is a 20amp circuit breaker.
Not sure why but as soon as mechanics inside printer moves is trips the breaker. Any Suggestions.
  • kingtmac Oct 03, 2008
    Thats the first thing I did. Only had the printer plugged in by itself and same result.
  • 104 Answers
Unplug other apliances connected to the same circuit.
Posted on Oct 03, 2008
Why is my Ricoh Aficio SP C411 DN laser printer shutting off soon as it is powered on
Go to user tools
than select the time for power save mode,reset mode set those timer off or for long time
Nov 10, 2015 | Ricoh Aficio SP C410DN Laser Printer
Aficio SP C410DN show "Please Wait"
what about the power is the power correct ?
Mar 23, 2014 | Ricoh Aficio SP C410DN Laser Printer
WHAT OTHER RICOH PRINTER IS THIS COMPATIBLE WITH???
The Aficio SP C410DN is compatible with these other printer models:
- Aficio SP C411DN
- Aficio SP C400DN
It is also similar to the Aficio CL4000, but some of the parts may be different.
Sep 02, 2010 | Ricoh Aficio SP C410DN Laser Printer
Reset photoconductor units aficio 410dn
www.ricohpr.com/.../Ricoh%20Aficio%20SP%20C410DN%20LTR%20%5B34245%5D... -
in order to reach the Ricoh restore factory menu, you need following steps.
1. push the yellow small "C" buttom. you can hear beep.
2. push the 3 numeric buttoms, in following order: 1,0, 7 .
3. push the big red "C" buttom, don't release for 5 minutes until you saw a copy windows popup on the screen.
choose the "copy sp", then trun off the power, and turn it on again.
now done, you have reseted the factory settings for the Ricoh Aficio munti-functional copier;printer.
If you really need the actual "Chip" then you will have to get a Service manual, inside there are circuit diagrams and circuit details.
May 06, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Aug 16, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Mar 26, 2009 | Ricoh Aficio SP C410DN Laser Printer
Cannot faind Ricoh Aficio SP C410DN Laser Printer Driver yuo know ther it is writ plise to gans-06@mail.ru
you can find the driver here http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11540&ricohmodelid=6342&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fcl410%2Fcl410en%2Ehtm
Mar 21, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh c410dn sc307
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
May 21, 2008 | Office Equipment & Supplies
Ricoh Aficio  SP C411DN Laser Printer Logo
226 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
