Question about Canon BubbleJet i560 InkJet Printer
Canon i560 Although the yellow ink tank is new ( and placed correctly ) I get the message that it is empty, what do i do now? Annemarie McNish annemarie.mcnish@gmail.com
  • ansmarie Oct 04, 2008
    I did do all that already and it did not help a bit - Tried it with another full tank too!
  • sknoppow Dec 01, 2008
    I replaced the blue cartridge, took it out and put it back in several times, but I still get a message that ink is low. Today it said the tank is empty, but it is not.
    President:
  • 4,402 Answers
Remove the cart and reinstall it.
was it replaced with refill or new?
go to canon site for more troubleshooting.
Posted on Oct 03, 2008
How do i empty waste ink tank on cnon i560 printer
You cannot do this yourself but you can google the problem and you should find a reset code that disables this warning, mine has been running for 12 months with this disabled
Jul 17, 2014 | Canon BubbleJet i560 InkJet Printer
My canon i560 printer won't print. I get an error message. The error message says to cancel print and press the resume button. This doesn't work. The yellow light is blinking 5 times then the green...
I got the same problem. I researched and found out it's the print head, you know the thing that moves side to side that releases the ink onto the paper. You either have to replace the print head( which costs around $50.00) or buy a print head cleaning kit because it might have dried ink in it. Hope this works for you( the kit didn't work for me, had to get a new print head)
Jan 21, 2011 | Canon BubbleJet i560 InkJet Printer
Will not print black although new black cartridge loaded. Cyan empty.
Canon printers tend to refuse to print if any of the tanks is empty. Replace the Cyan.
Dec 28, 2009 | Canon BubbleJet i560 InkJet Printer
My error message says the used ink tank is full. How do I empty it?
You can't empty it, it's a set of pads covering the whole bottom of your printer. They only cost around $10.00 but you need a shop to replace and reset the waste ink counter.
Sep 02, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
How do I empty the use ink tank?
You can still order the ink absorbers for this model, but only a shop can access the diagnostic mode to reset the counters and clear the error code.
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
I have a canon i560 ink jet printer. the yellow light flashes and the message reads The used ink tank is full. it won't print anything
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Canon BubbleJet i560 InkJet Printer
Canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Jul 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Ink cartridges wont print
same problem!!!!! temping to get another printer - help!!!
Dec 19, 2007 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
70 people viewed this question
old marine
old marine
