Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
IPOD Shuffle Will Only Load 8 Songs
I have a 2nd gen IPOD Shuffle. It has worked fine for a year but now when I plug the Shuffle in, it will only load about 8 songs from my library. The capacity bar is only about ten percent full and the capacity shows 8/250 songs loaded.
I've tried the 5 Rs, I've tried updating itunes but the same 8 songs will get loaded. And I can't drag and drop any in either. Any help would be appreciated.
  • 2 more comments
  • deacon211 Oct 04, 2008
    Thanks for the suggestion Wiz. Sadly, it didn't work.
    First of all I'm running Vista which made finding the format function difficult. Once I did, I got the message "Cannot complete format" several times before I could get it to work and wipe the drive.
    After I successfully reformatted, I attempted to drag and drop some songs into the shuffle from the library directly. Of the 20 or so I selected, only about four copied. Syncing was similarly unsuccessful. Lastly, even autofill only selected about 20 songs.
    So, it works better than before but for some reason still won't fill the entire drive volume with music.
    Anything else that might help?
  • deacon211 Oct 06, 2008
    Still no joy I'm afraid. Will still only load 20 songs.
  • deacon211 Oct 09, 2008
    Hey, thanks again for the attempt. It turns out that it was actually a authorization issue. Once I selected Authorize Computer, it worked fine! Don't know why it deauthorized in the first place.
  • Anonymous Jan 08, 2009
    Getting
    Genius:
  • 1,689 Answers
Okay plug the shuffle to a windows based computer, then use "Disk Management" to format it, once it is formatted, run the iTunes then perform an update for the shuffle. once completed try to load songs and this should work for you now..
if you have other questions just lemme know.
Posted on Oct 03, 2008
  • 1 more comment
  • marlon john madrid
    marlon john madrid Oct 04, 2008
    why not try to use another computer or a Mac to do this, with iTunes 8.0...
    the format for vista is under disk management, or "computer" both will work but it will be better if you do it through disk management.
    marlon john madrid Oct 06, 2008
    5 r's still did not help, plus formatting, i guess it will be best to contact Apple for further information on this issue that you have, it may be the fimrware or the hardware that's causing the problem.
    marlon john madrid Oct 11, 2008
    usual issue when you upgrade itunes to 8.0
    but good thing all is well
Ipod shuffle (2nd gen) completely dead
you are still under warranty...take it to the sony apple store...they will fix it /replace it or tell you there is cost if it not the battery (note do not tell them you charged overnight, and for the future do chage any gadgets more than 3-4 hrs) when you do charge over night you are actually shorten the battery life span or overcharge....so as soon as you come home from school,work,whatever cell/ipod or any other device needs to be charge...charge it now and unplug before you go to bed....
Jun 26, 2009 | Apple iPod shuffle Second Gen. Silver (1...
IPOd Shuffle 2nd Generation incompatibilities with iTunes
click on your ipod icon and that should be songs on your shuffle, play to see if they really are on there. sometimes it tricks you...
Jun 08, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Apple ipod shuffle 2nd generation
it seems some songs are corrupted i prefer suggest try to reformat your unit off course you should be aware that if you start reformating your unit all of the save files will be deleted.
but it will surely clean the folder.
thanks,
May 27, 2009 | Apple iPod shuffle Second Gen. Silver (1...
ITunes+used 2nd gen ipod shuffle not working.
Ok, try completely uninsalling itunes, then reinstalling it. then importing the songs via add to library.
Jan 05, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Cant get songs onto ipod shuffle.(daughter has ipod touch)
When you go into the ipod section on iTunes, click the music tab, make sure 'sync music' is checked and 'selected playlists:' is also, then check the playlist you want to use. Click 'sync' button
If that don't work go back to the summary tab and hit 'restore' and follow the instructions to reset the ipod, resync and all should be fine.
All the best
Sean
PiDigital
Dec 31, 2008 | Apple iPod shuffle Second Gen. Silver (1...
IPOD Shuffle deletes songs if I delete them from the music library in Itunes
You have to keep all the songs that you want on your iPod on your computer, otherwise you will get this problem. So if you want song "a" on your iPod it must also be in your iTunes library at all times unless you don't want it on your iPod anymore
Oct 03, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Settings/content pane in itunes for adding songs does not show up
had the same problem. Just reinstalled Itunes. As of July 30th 7.7.1.11 Version. Fixed the problem right up.. I was able to register and get my songs to show up.. Good luck and happy listening...
Jul 21, 2008 | Apple iPod shuffle Second Gen. Silver (1...
The 5 Rs: Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with iPod shuffle. Try
these steps one at a time until the problem is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
â Reset iPod shuffle by turning it off, waiting five seconds, and then turning it back on
again.
â Retry with a different USB port if you cannot see iPod shuffle in iTunes.
â Restart your computer, and make sure you have the latest software updates
installed.
â Reinstall iTunes software from the latest version on the web.
â Restore iPod shuffle. See “Updating and Restoring iPod shuffle Software” on
page 26.
Jul 16, 2008 | Apple iPod shuffle Second Gen. Silver (1...
My Ipod shuffle does not work, when I switch on the ipod, I see orange light on and off..it does not show green. I charged the battery for more than 4 hours. Can anyone help ne why is this happening and...
I am not sure about the 1st generation but the 2nd generation definitely charges via the USB connection. If you don't hear the music its because there are no songs on your device. When you initially add songs, they go to the Library in iTunes, not the Shuffle. Just drag and drop your songs from the "Library" to your "Device" in iTunes and then you'll notice them get sync'd with the Shuffle.
Jan 14, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod
Do you get any error messages?Or you dont know hw to transfer?Pls post back so that we can help you fix it..
Nov 21, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
