Question about Garmin eTrex Venture GPS Receiver
The unit will not aquire the satelites, it shows many but usually only 1 or 2 have any signal strength, usually this unit aquires at this location in less than 1 min!
    President:
  • 4,402 Answers
Was the unit dropped? i suspect a broken receiver.
Posted on Oct 03, 2008
Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Jun 25, 2010 | DISH Network 322 DTV Receiver
Unit shows 3 bars for signal strength yet the
This is a very old radio, and your antenna could be shot too. Try another antenna first.
Mar 01, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
I takes close over 3 minutes for my garmin 765T to locate a sattelite and I leave in a major east coast city. is something wrong with the system or is this normal
Holding the satellite signal strength indicator icon (upper left hand corner of screen) for a few seconds with your finger brings up a visual display showing signal strength of various satellites, accuracy, speed and elevation.
From a cold start - I too have experienced 2 to 3 minute wait times for satellite aquisition, so I would presume this is a normal. I own three different Garmin units apart from the 765T and satellite aquisition times vary on all three, most aquire satellites in under 4 minutes. Traffic on the other hand seems to take a while to load as this is dependent on availability in your area.
Nov 30, 2009 | Garmin nuvi 765T GPS Receiver
When I turn on the unit (new batteries installed) it shows 9 - 11 satelites, but it doesn't acquire any of them. Any suggestions?
if it shows 9-11 satellites, it has aquired them. let it sit for a bit until it gets the proper data for them. if it has just been turned on for the first time or is left off a lot it may take 3-5 mins to figure out its locations.
Nov 10, 2009 | Garmin GPS
My Garmin Nuvi 350 does not aquire sattalites?
Make sure it is in its mount. The antenna is in the mount and needs to be connected tight also make sure You have a view of the sky and not parked in a garage that blocks the signal
Oct 28, 2009 | Garmin Nuvi 350 Car GPS Receiver
Unable to aquire satelites garmin nuvi 255 w. flew from newfoundland to toronto. unable to aquire sattelites at toronto.
When you change geographical locations with any GPS it will take a lot longer for the GPS to acquire the sattelites. Hold the GPS out in an unobstructed area and switch it on. Be patient it will acqurie the signals if it was working before you left home.
Apr 01, 2009 | GPS
My tom tom ONe cannot get a valid Satelite Signal just stays wait
If you are indoors then move outdoors to get a signal.
If you are outdoors then move your location by a few yards and sometimes it will suddenly aquire the satellites.
Happens occasionally with my unit. I normally set a route up then start driving and it suddenly starts to work OK.
HTH
Peter
Mar 07, 2009 | Tomtom ONE GPS Receiver
Garmin fortrex 101 won't aquire any satelites
Does it pick up any at all? you need 3 to get a fixed posistion. If you see one or two picking up then it may be your location. Also try doing a firmware update, I have seen that fix this problem on other units.
Jan 21, 2009 | Garmin Foretrex 101 GPS Receiver
Garmin gps 72 not aquiring satelites
Press POWER ON and PAGE buttons at startup and leave for 20 minutes to initiate
Nov 09, 2008 | Garmin GPS 72 GPS Receiver
Garmin GPS problem
I have a 276C that has the same problem. Garmin has a unit with this problem and is working on a solution. The problem is that the real time clock loses time when the unit is turned off and disconnected from a power source. As a result when you turn on the unit it thinks the satelites are in a different orbit than where they actually are. The unit will continue trying to aquire forever and not find the satelites. You have to select "New Location" from the menu and select "Autolocate" and the unit will start to look for any satelites in view. The unit should get a fix within 15 minutes. This is a very frustrating problem having to reset it every day. There is a new version of firmware (5.3). I don't know if the problem has been fixed with this release.
Jun 15, 2008 | Garmin GPSMAP 276C GPS Receiver
Garmin eTrex Venture GPS Receiver Logo
117 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
