I have a wharfedale L15t11W hd ready tv and cannot get a pc piclute the emachines and xp logo comes up then a blank screen with a blue box saying no support - whats the problem and how do I fix it?
  • 4,234 Answers
My first guess would be that the settings of the display are too high and not supported by the TV. Look in the owner's manual for the resolutions that are supported and set the monitor on the computer for one of those settings. The startup screen is always in the "lowest common" setting.
Dan
Posted on Oct 03, 2008
Screen goes blank on Samsung LCD TV. Comes back on if tilt or move screen.
I'm gonna go out on a limb and say you may have a LCD tab(s) that are failing.
Jan 26, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Emachine T3304 comes blue screen, windows would not turn on
Mamum23 if you install windows xp pro and the problem persist it could be a few reason like: 1. Have a hardware that is interfering with the boot (printer, external HD, etc) 2. Could be the hard drive that is having problems in a few sectors (blocks) and you may need a new HD. 3. Could be the modemboard slots but that could be really rare. If I was you I made the troubleshoot 1 and then 2.
May 06, 2010 | E-Machines eMachines Desktop PC
Speakers not working
I have a wharfedale 32 HD Ready didital LCD TV and the headphone socket does not seem to work...have used four working headphones that work on Ipods and Hi Fi but they do not work on TV is this a tv fault or do I need a mono small jack on headphone ?
Dec 01, 2009 | Televison & Video
Iomega Screenplay Pro HD Multimedia Drive works on PC but not on
If the blue light continues to flash after the screen goes black, then you need to reinstall the firmware. Look at http://screenplayprohd.wikia.com for information about getting the firmware and installing it.
If the blue light goes solid after the screen goes black then you probably just need to switch the NTSC/PAL selection. Press that button on the front panel several times, waiting a few seconds inbetween in press. If it continues to be invisible, plug the drive into another TV using the composite cables instead of HDMI to confirm if the menu comes up at all. If it does, reinstall the firmware.
Sep 14, 2009 | Iomega ScreenPlay
I am getting a blue screen that says mode not supported when I try to view HD channels
This usually indicates that you are trying to watch a screen in a higher resolution than the Tv will actually handle
Aug 17, 2009 | Televison & Video
Not DTV ready?
it meens the tv set is in dtv and the dtv conection is not set up.
hd tv is a red blue a green cable.
and the antena conection needs to come from a converter box if signal is coming from antena if from sat or cable you should have a hd box that feeds your set.
hope this helps.
daniel.
Jan 13, 2009 | Panasonic CT-27SC13 27" TV
COMPUTER WON'T WORK WITH NEW HD LCD TV
Sounds like the PC has too high a screen resolution set for the TV to handle
Re-connect PC to PC monitor , change display resolution to 800 x 600 (right click desktop, properties, settings, slider marked "screen resolution" to leftmost side, save settings.
connect PC to TV, TV should be able to display PC data now.
Go through same procedure with PC connected to TV, move slider to 1024 x 768 posn. (depends on TV model as to what it can cope with) - *apply* this setting & see if TV is able to display at this resolution.
If it is, desktop will appear - if not, you'll get the warning box generated by the TV...don't worry, in 15 secs, the PC will revert to the old (working) setting.
Hope this helps.
Dec 19, 2008 | Computers & Internet
Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
TELEVISION
This user manual should help!
http://portablemedia.manualsonline.com/manuals/mfg/wharfedale_international/l15t11wa_l15t11wc_l19t11wa_l19t11wc_l20t11wa_l20t11wc_l19t12wa_l19t12wc_l20t12wa_l20t12wc_l22t11wa_l22t11wc.html
Jan 13, 2008 | Televison & Video
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
