Question about Systemax Neotach 3300 Notebook
Cant reformat i cannot reformat my neo notebook, it cannot continue since there's a report that my hardisk is not connected, i did not do anything to my hardware, i was in the middelof something when it suddenly crashed. please help
  • flortag5 Oct 03, 2008
    thanks much, you're right that was also my suspicion though i was thinking i may be wrong. i guess a hardisk replacement is inevitable. thanks again pal!
    Genius:
  • Systemax Master
  • 1,250 Answers
Check the status of your hard disk on the bios of your laptop is it detecting or not, if its not then you have to replace the hard disk
Posted on Oct 03, 2008
Windows installation setup says not find any hdd disk drives installed and says cannot continue
You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key. Check if BIOS still recognizes a hard drive. If not, you need to physically reconnect drive and try again.
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
My neo BASIC5100N "hangs" all the time
Depending on the version of windows that is on that machine you may need to update the drivers. You also could have an issue with the BIOS being an older version. Lastly you should check the power saving settings.
May 05, 2017 | Computers & Internet
Hellow, my problem is the all famous "Windows could not start because of a computer disk hardware configuration..." and i cant do anything, because it shows right after i turn my eeepc...
maybe the system cannot detect your hardisk because it's not working or have a bad sector. or try to reformat your laptop you need an OS save on the USB or if you don't know how to format try to go to asus service center
May 21, 2011 | Computers & Internet
Reformat my neo notebook
You have to get the recovery disks from the manufacturer. Depending on how old the notebook is, they may send them for free. Otherwise they are about $15-$25.
Nov 18, 2010 | Computers & Internet
My 3000pc wont boot because it says it has a badPBR
You have to reformat or repair your operating system. there is an option when you start to reformat/repair your operating system, but first you should back-up your files to other computer, make your hardisk as a slave to other computer, there is a jumper on the back of the hardisk, place it on the slave pin then put it on the other computer without taking off the hardisk of the computer you will used
Sep 27, 2010 | Dell Dimension 3000 PC Desktop
My hp 530 notebook couldn't load into windows. It will just show blue screen and restart. I've changed the hardisk but its the same thing. It seems its not seeing the hardisk
In this case it is an windows problem you need to reformat your notebook. So that the windows have fresh copy. If the same things happen the problem is the RAM you need to replace the RAM.
Jul 27, 2010 | HP 530 Notebook PC
Laptop shutting down
Leave your laptop on, without doing anything.
If it shuts down , you may be having an overheating problem.
If that is the case, remove the accumulated dust from the fan or fans, and try again.
(A vaccum helps here)
If no improvement, a deeper clean may be needed, which requires opening the laptop, and get to the heat sink area, clean and apply fresh heat release compund to the processor.
Please don't forget to rate if the answer helps
Aug 25, 2009 | ASUS A8Jm Notebook
I cant re format the acer4620series
hi!!!
maybe the hardisk has defect or damaged
try to borrow some hardisk from your friends
or buy new one and then reformat!!!!
Oct 30, 2008 | Acer Aspire 3050-1733 Notebook
Systemax AOL Optimized
DOES YOUR HARDISK DRIVE DETECTED?IF NOT, TRY TO DISCONNECT IT FROM THE SYSTEM ,TURN OFF YOUR PC,POWER ON, PRESS F10 AND OPTIMIZE DEFAULT SETTING, SAVE IT.TYURN YOUR PC OFF CONNECT THE HARDISK,IF IT DETECTED, AND NO WINDOWS APPEAR,REFORMAT YOUR SYSTEM.
May 27, 2008 | Systemax AOL Optimized PC (100607) PC...
External Segate 200 GB SATA Hardisk (USB 2.0 connection to PC)
I appears the volume may have been corrupted. YOu should run data recovery on the drive if you need any of the content. If not reformatting the drive, should restore it. If the contents are not important, or you have it backed up, go ahead and connect it to the MACINTOSH and format it for MS-DOS.
Unless it is physically damaged ( clicking, beeping, knocking ) it shoud be usable.
Hope this helps.
Oct 19, 2007 | Seagate Barracuda 7200.7 200 GB Hard Drive
Systemax Neotach 3300 Notebook Logo
112 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
