Question about Xerox Computers & Internet
How to setup secured printting on a xerox workcenter pro90 copier?
    President:
  • 2,072 Answers
Solution: Send a Secure Print Job From a Workstation how to setup secured printting - bttn_print.gifMake Printable bttn_email.gifE-mail this page
  1. With your document open in the application, click on [File] on the toolbar and then select [Print] from the menu. The Print window will be displayed.
  2. Select the printer in the Name field.
  3. Click on the [Properties] button.
  4. Click on the [Paper / Output] tab.
  5. Select [Secure Print] from the Job Type pull-down menu.
  6. Click on the [Setup] button (just below the Job Type menu) and enter a 4 to 10-digit code, to release the job at the printer, in the Enter a 4-10 Digit Secure Print Passcode field.
  7. Enter the code again in the Confirm 4-10 Digit Secure Print Passcode field, and then click [OK].
  8. Make any other required selections in the print driver and the click [OK] twice to send the job to the printer.
Solution: Enable Release Ahow to setup secured printting - bttn_print.gifPrint bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution as it requires knowledge of the network’s Authentication environment.
The WorkCentre Pro will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address).Before you begin, print a Configuration Report and make sure the WorkCentre Pro has an IP address, and the HTTP protocol enabled. See the Related Items below.
From the workstation:
  1. Click on [Start], point to [Programs], and select [Internet Explorer] to open an Internet Explorer browser window.
  2. Enter the IP Address for the WorkCentre Pro followed by /diagnostics/secureReleaseAll.dhtml in the Address field, and then press [Enter] on the keyboard. For example, type: xx.xxx.xxx.xx/diagnostics/secureReleaseAll.dhtml (where x represents the IP Address). A Secure Print Release All window will be displayed.
    NOTE: The URL is case sensitive; secureReleaseAll must contain a capital R and capital A.
  3. When prompted, enter the username and password in the fields provided.
    NOTE: The default username is admin and is case senstive. The default password is 1111.
  4. Click on the check box next to [Enable release of all secure print jobs with the same user name and passcode] to insert a check mark.
  5. Click on [Apply].
  6. Click on the [X] in the upper, right corner to close the browser window.
Posted on Oct 04, 2008
  • Rick Kasper Oct 04, 2008
    Xerox provides Secure Print and optional Image Overwrite to protect your classified or private information. See your System Administrator for more information about security.
    1. Secure Print: is a standard network feature. Jobs are held in the print queue until you enter your personal 4-10 digit Secure Print ID.
    2. Image Overwrite: is available upon request as an optional feature. When available, the overwrite components are enabled by the Machine Administrator. The two components are Immediate Image Overwrite and On Demand Image Overwrite.
    • Immediate Image Overwrite: makes sure that all information related to a job is immediately overwritten after the successful completion of each job. You can view job overwrite status at the machine using the Job Status pathway button located on the Touch Screen. The system will display a fault message and instructions if the overwrite was unsuccessful.
    • On Demand Image Overwrite: irretrievably overwrites all of the physical areas of the disks that hold data. All jobs in the active queue will be deleted and overwritten. Jobs sent during the overwrite process are held and released after the overwrite process has finished.
Inside yellow
please i need how activation code xeror 7120 workcente
Jan 14, 2014 | Xerox WORKCENTER 6505DN COLOR LASER MFP,...
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
I need to print standard size 10 envelopes. Where/How do I load them? WorkCentre7335
Some setup will be necessary both on the WorkCenter and in your software. I will describe these steps and leave you with a link to Xerox to check as a reference:
On the WorkCenter 7335
1) In the Bypass tray, load the std. 10 envelopes width-wise with the side to be printed down, flaps tucked in and with flaps entering the printer first. Slide the guide to just touch the edges.
2) Touch <Change Settings> on the WC 7335 screen
3) Select "Envelope" from the "Paper Type" list
4) Select "No. 10 Env" from the "Paper Size" list
5) Select "Save"
6) Select "Confirm"
In your software:
As you did not specify your software, it is important to note that whatever application you are using, the following settings must agree with the steps above:
1) Feed method = Face down, Clockwise rotation
2) Feed from = Bypass
These options may be chosen in different ways depending on your software program.
You may review these setup steps for Word here:
Xerox WC 7335 Print Size 10 Envelope
Jan 25, 2010 | Xerox WorkCentre M118 Laser Printer
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Aug 07, 2009 | Xerox Office Equipment & Supplies
Secure Printing
What brand and model number copier is this?
Jun 09, 2008 | Office Equipment & Supplies
Computers & Internet Logo
1,135 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
