Question about Zanussi Washing Machines
Zanussi FL884 Washing Machine
I cannot open the door and my washing is stuck in there. It seems like the catch is broken as the handle has no spring in it.
Am I right in thinking there must be an emergency release? If so, do you know where it is? I can't find it and there is nothing in the manual.
Many many thanks
rob
  • robbo400 Oct 12, 2008
    Tresilla
    thanks. got it open myself and have ordered the spare part needed. Spent around £15 instead of £100 to repair it or £250 for a new machine.
    Thanks so much. Greatly appreciated
    Rob
    President:
  • 1,462 Answers
There is no emergency release.
two ways of opening door.#
break handle off and you can lever door peg with a small screwdriver
or
disconnect from mains
take top off. feel down to the door interlock and feel for the end of the door peg. push this sideways and you can sometimes release the door
Posted on Oct 03, 2008
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
Zanussi FL884 Washing Machine door lock broken.
More likel that the door latch or handle is broken.
Only way to open door now is to remove the top cover and force the door lock open from inside, you may possibly break the lock by doing this, but there is really no other alternative.
Mar 29, 2010 | Washing Machines
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
My door handle on my zanussi fls 1183w washing machine has broken and ive bought a new handle but dont know how to get old one out can you help please
normally on zanussi doors they have 5 or 6 screws around the edge on the inside of the door if you try to undo them and take apart the door the handle should come out be carefull not to drop the glass
Nov 11, 2008 | Zanussi Washing Machines
Zanussi fl884 door will not open
Try http://www.partmaster.co.uk/cgi-bin/catalogue.pl?section=10422 For parts they have lots on there and very good service,think they will deliver to ireland as is a U.K company
Mar 06, 2008 | Washing Machines
WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Dec 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
Door latch broken, clothes stuck inside!!
not that easy. best way to try is to chew away as much of the handle as possible till the door peg is in view then prise open with a small screwdriver. you can sometimes reach down the inside the machine from the top and feel for the tip of the peg and do it that way
Apr 01, 2007 | Zanussi FLA1001W Front Load Washer
Washing Machines Logo
473 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
