Question about RCA HD52W59 HDTV Projection Television
RCA d52w26 Field service menu
I got a rca hdtv rear projection 52'(ITC222) from my sister (after it was fried by lightening)We have replaced a couple of fuses and transistors,everything seems to be going fine,But I'm having a GREAT time trying to get the geometry and colors straight again cuz my brother-in-law was into the service menu and played with the settings,I was wondering if anyone had written done or could get the original settings for the tv and the field service menu.
  • fixmetvplz Oct 03, 2008
    I need the settings for the field service menu ie: v-slope = +a0, and so on.
  • dennyscott Dec 05, 2008
    I can't get the set to go into the service menu after doing the power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. Does anyone know why?
Can you please tell me how you got the service menu? i really need instructions this way i can try it on my tv which has same problem and if i get it i will tell you how, i just need to know how to do the service menu thing? PLEASE HELP
Posted on Mar 07, 2009
    President:
  • 4,402 Answers
RCA > HD52W66
itc222a chassis
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec.
http://home.austin.rr.com/doctorjoe/ITC222align.pdf
Posted on Oct 03, 2008
My mom has 52 inch rca and the convergance option on the menu is gone
Very easy and inexspensive repair. You can get the RCA repair kit called the ITC222 & ITC222A convergence option missing repair kit from www.tvrepairworld.com the kit contains the parts and the instructions for the repair
Apr 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
HDTV monitor 52 in. Model #: D52W26 Serial #: G072CU07E colors are separated, warped screen and cannot find auto convergence
Very easy repair. The ITC222 and ITC222A convergence option missing repair kit available from www.tvrepairworld.com will solve that issue. Its listed under the RCA repair kits and has the parts and the CD with repir instructions.
Mar 31, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca 52 in projection t.v has problems powering up
Push and hold power button. If it cycles and blinks on/off in 3s or 9 times, it is a power problem. Replace the deflection board. Cost about 250.00
Jan 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Looking for the auto convergence menu on my rca rear projection tv.
Its under the setup section of the on screen menu. If its no longer there then you will need the RCA repair kit called ITC222 and ITC222A convergence option missing repair kit. from www.tvrepairworld.com which has the components and the CD with instructions included with the kit.
Dec 26, 2009 | RCA R52WM24 52" HDTV Projection Television
Fixing rca D52w26 convergence problem can you try fixing with remote
No,must replace parts,These websites,have convergence kits for many DLP TVS.Tv Repair
World.com,Tv Repair kits.U know how to solder right?
Oct 23, 2009 | RCA HD52W56 52" Rear Projection HDTV
Divergence not working on RCA HDTV monitor 52" D52W26
sound like the common fl231 fuse problem. consult the fl231 problem article under the tips and tricks section. this is probaly the simplest most inpensive repair on this set
Jan 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52W26 Convergence board
Yes the D52W20 and the D52w26 are both ITC222 chassis they are exactly the same
Jul 17, 2008 | RCA P52926 52" Rear Projection Television
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
1,238 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
